Injector o-rings
Old Feb 27, 2002 | 04:18 PM
Mikey3000's Avatar
Default Injector o-rings
on my h22 (which is still on a stand) i have an str manifold. there are 2 kinds of o-rings, the hard plastic ones and the soft rubber ones. how do both of these fit on the bottom of the injector, and into the manifold? i can only fit one set of o-rings on there. are both of them supposed to go on there?
Old Feb 27, 2002 | 08:29 PM
SilverLudeSi's Avatar
New User
Default Re: Injector o-rings (H22Turbo)
With the stock injectors, the hard plastic ring (the phenolic spacer) goes on the bottom closest to the manifold and the rubber o-ring goes on top. From what I have read, you can just ditch the stock phenolic spacers and grind out the rubber o-rings a little for a good fit. I am doing this right now with some rc 550's. Here is what I mean.
See, phenolic spacer won't fit so get rid of it b/c it doesn't do anything.
Old Feb 28, 2002 | 06:27 AM
Mikey3000's Avatar
Default Re: Injector o-rings (SilverLudeSi)
i see. so i don't need to use the hard plastic one at all? just put the soft rubber one in the manifold and plug the injectors in?
Old Feb 28, 2002 | 08:28 AM
New User
Exactly
Old Feb 28, 2002 | 08:48 AM
Mikey3000's Avatar
awesome thanks for the help!
Old Feb 28, 2002 | 01:24 PM
New User
No problem, let me know how it goes b/c I am going to be doing the same thing this weekend. And what does your signature mean?
Old Feb 28, 2002 | 01:58 PM
Accord94DX's Avatar
The dukes of hazzard man! TV show. Damn good one mind JoO.......
Old Feb 28, 2002 | 04:14 PM
Mikey3000's Avatar
Default Re: Injector o-rings (Accord94DX)
lol yeah it's Boss Hogg's fav. phrase from The Duke's of Hazzard, an 80's show. one of the best shows ever too! you're right though it doesn't go right with my screen name. maybe i should change it to Boss Hogg.
Old Mar 5, 2002 | 07:24 PM
TEK4DR's Avatar
New User
Default Re: Injector o-rings (Boss Hogg)
hey boss hogg off the topic but where did you get the str manifold and how much??
Old Mar 18, 2002 | 10:06 PM
Markaccord95's Avatar
Default Re: Injector o-rings (TEK4DR)
you do not want to get rid of these spacers, they serve a purpose, to remove heat from getting to the injector. the not 'getter dun' way would be go to someone with a press and have them punched out to size so they will fit, and then trim the oring
Old Mar 18, 2002 | 10:28 PM
New User
Default Re: Injector o-rings (Markaccord95)
I was just going by what sgt and some other people said on this thread: https://honda-tech.com/zerothread?id=133644&page=2
I actually ended up just grinding the spacers out with a dremel when I did the rubber o-rings. I figured might as well use them if I can easily make them fit. I just got the injectors and rail all installed today, but still haven't done the fpr. Everything seemed to fit sungly though.
Old Mar 19, 2002 | 09:03 AM
honda designed it as a heat defuser, putting in metal spacers wont correct it, so yes, cutting the current spacer is the correct way to go
Old Mar 19, 2002 | 10:46 AM
apexii's Avatar
Did you have a problem grinding the rubber seals with a dremel? i did not even attempt to do the rubber seals. I'm having my dsm injectors machined to fit the stock seals, rather than try to dremel 8 seals all the same...
[Modified by apexii, 2:47 PM 3/19/2002]
Old Mar 19, 2002 | 11:21 AM
New User
Default Re: Injector o-rings (apexii)
They all seem to fit fairly well. I ground them just a little at a time, while continuously test fitting them on the injectors. Like I said, I havent finished the whole fuel system yet, so I havent started the car up, but I don't anticipate any problems. If some of them leak, I will just go buy some more seals and try again.
SkoundrelUSA
Sep 2, 2006 07:32 PM
jtracing919
Mar 23, 2006 04:50 AM
Steak84SS
Mar 20, 2005 08:44 AM
Farnsrocket
Dec 1, 2001 06:04 AM
