1994 LX fan dial won't work - how to test/remove?
just bought 94 LX with a/c. When I turn the fan **** to any speed nothing happens. If the a/c button is pushed "on", the fan **** will engage something (a/c compressor or cooling fans?) but still no air blows through any dash vents. Is it the
1. fan blower speed switch
2. relay/resistor to the blower motor
3. blower motor
what is the best test method and how to remove the switches or blower motor?
where is that sucka?
thx in advance
3. blower motor
thx in advance
chk to see if u are getting power and ground at blower motor , it is located lowwr right side of dash,below glove box , there is a plug with 2 wires going to it ..,,,if you get no air from vents and you have power and ground ,, you got a bad blower motor ,,,,,,,
P.S. ,give it a good wack see if it comes on ,,if it does u got a bad motor
Solid advise - thanks
is there a resistor/relay inline from the dash switch to the motor? I did search the tech here and found these mentined...if so, where are/is they at??
checked fuses - good. Found motor under dash (easy) tapped it and she kicked right in
So I'll get a motor now before it craps out for good.
thx for the info
thx for the info
idewson
Mar 4, 2007 07:34 AM
