Heater Stopped Working
Old Nov 8, 2009 | 07:05 PM
jwh1276's Avatar
Default Heater Stopped Working
I have a 04 Pilot and my front blower motor suddenly stopped working. The rear blower works fine and I can adjust the fan speed in the back using the fan control for the front. I have checked the fuses which are OK. I removed the blower motor and hooked it up to power, which the fan turned on. Also, I removed the blower motor relay from the fuse box and barely pressed it into the female contacts. The relay made a 'click' upon engaging with the female end so I believe that it is working properly. Not sure where to go from here. Any input would be appreciated.
Old Nov 9, 2009 | 06:14 AM
fcm's Avatar
fcm
Old Fart
Default Re: Heater Stopped Working
Blower resistor.
Do you have a multimeter or ta 12V test light?94
Old Nov 9, 2009 | 09:55 AM
jwh1276's Avatar
Yes, I have a multimeter. Would a faulty resistor cause the entire front blower to stop working?
Thanks in advance.
Old Nov 9, 2009 | 11:14 AM
fcm's Avatar
fcm
Old Fart
Thanks in advance.
Yes it can.
The blower motor should have 12V+ going to it when ign. is turned on, the ground is supplied by the blower speed switch, either directly, [full speed] or through resistors for slower speeds, remount blower and plug in, find which is the 12V+ lead and then supply a ground to the other lead/terminal using a jumper lead from chassis ground. if blower works, [full speed] replace blower resistor. 94
Old Nov 9, 2009 | 08:05 PM
jwh1276's Avatar
Thanks...I will try this and let you know.
Old Nov 11, 2009 | 06:18 PM
jwh1276's Avatar
It worked! I ran a ground wire to the chassis and the blower motor kicked on full blast. Looks like I will be replacing the blower resistor.
Thanks for your help.
Old Nov 25, 2009 | 08:50 AM
jwh1276's Avatar
Thanks again fcm, I installed the blower motor resistor/transistor and the heater fan now works. I hope this info will help someone else.
custm-1
33
Sep 8, 2018 10:49 AM
Nick998
Dec 22, 2011 06:47 PM
chief455
Sep 13, 2005 09:41 PM
unclejemima
Jul 19, 2004 04:32 PM
