d16y5 into a 94 hatchback
Old Sep 12, 2005 | 06:31 PM
Bense's Avatar
Default d16y5 into a 94 hatchback
so after many hours of research on how to get the best gas mileage, i have decided that i want to put a d16y5 into my 94 hatch. it's an obd2 motor and it uses the P2N OBD2 ECU. However my car is obd1. I want to use the VTEC-E function and i've thought of two options.
1. i can rewire my car to be obd2 and use the p2n ecu (i don't want to do this)
2. i can use some other ecu, i have a p05 that i'm not using, and i'm currently using a p06. could i use any of these or possibly a chipped p28 to run the motor while having some sort of switch in the car that engages/disengages the 3valve mode.
3. OR could i use a d15z1 92-95 vtec-e vx ECU?
it would be ideal if i could get option 2 to work. this way i could be cruising in 3valve mode at 80mph at ~3000rpm which is above the crossover on the p2n.
thanks in advance.
Modified by bense at 11:49 PM 9/12/2005
Old Sep 12, 2005 | 06:43 PM
Jizzmaster Zero's Avatar
(banned)
Default Re: d16y5 into a 94 hatchback (bense)
I have a y5 in my '92 dx. Well it's a Z6 block with a Y5 head. I use a chipped P28 ecu with uberdata to control the vtec-e and it works ******* great. Your best bet is to just convert to obd1 and do that, it is painless. And you can set the vtec engage to wherever you want to get crazy good gas mileage.
Old Sep 12, 2005 | 06:44 PM
SOHCejcivic's Avatar
Default Re: d16y5 into a 94 hatchback (Jizzmaster Zero)
y5s are hx's right? kinda pointless imo.
Old Sep 12, 2005 | 06:56 PM
Bense's Avatar
Default Re: d16y5 into a 94 hatchback (SOHCejcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">y5s are hx's right? kinda pointless imo. </TD></TR></TABLE>
uh, how is it pointless if i'm trying to get better gas mileage?
Old Sep 12, 2005 | 07:09 PM
(banned)
You can easily get over 50 mpg with a Y5
Old Sep 12, 2005 | 07:15 PM
Bense's Avatar
and that's why i want it!
Old Sep 12, 2005 | 07:27 PM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jizzmaster Zero &raquo;</TD></TR><TR><TD CLASS="quote">I have a y5 in my '92 dx. Well it's a Z6 block with a Y5 head. I use a chipped P28 ecu with uberdata to control the vtec-e and it works ******* great. Your best bet is to just convert to obd1 and do that, it is painless. And you can set the vtec engage to wherever you want to get crazy good gas mileage.</TD></TR></TABLE>
what wiring harness are you using?
Old Sep 13, 2005 | 08:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bense &raquo;</TD></TR><TR><TD CLASS="quote">
uh, how is it pointless if i'm trying to get better gas mileage?</TD></TR></TABLE>
you edited the original post. you didn't say anything about wantin good gas mileage originally.
makes sense now. go with it.
Old Sep 13, 2005 | 10:23 AM
Bense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCejcivic &raquo;</TD></TR><TR><TD CLASS="quote">you edited the original post. you didn't say anything about wantin good gas mileage originally.
makes sense now. go with it. </TD></TR></TABLE>
i edited it to add option three. not my fault that you can't read. which is why the first reply mentioned something about gas mileage.
Old Sep 13, 2005 | 10:25 AM
.Ry's Avatar
.Ry
But the money and time you spend getting everything might equal what you would pay in gas.
Old Sep 13, 2005 | 01:07 PM
Bense's Avatar
Default Re: (turner7205)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by turner7205 &raquo;</TD></TR><TR><TD CLASS="quote">But the money and time you spend getting everything might equal what you would pay in gas. </TD></TR></TABLE>
which is very true, however it is a fun project and makes more economical sense than swapping to a b-series. plus my motor is burning about a quart of oil a week.
Old Sep 13, 2005 | 05:55 PM
.Ry's Avatar
.Ry
I agree with the project idea and its something to do. Go for it
Old Sep 13, 2005 | 07:40 PM
Kista20's Avatar
thats what I was gonna say... obd1 chipped p28 and uberdata. Personally if you can get 50 mpg I'd like to see that. I'm not calling bs or anything but I would like to see it. The absolute best I got out of mine is 435 miles out of a tank so that would probabaly be 40 or so mpg. I would love to see what a y5 could do in a hatch.
MurtazaDSM
Engine Management and Tuning
Dec 23, 2010 08:25 PM
JohnData
13
Apr 26, 2010 06:11 PM
HondamanXxX
Aug 10, 2007 07:59 AM
Eibach95Civic
22
Apr 15, 2007 09:05 PM
4EN[sic]
Mar 22, 2007 10:31 AM
