Need Help guys- ECU
Old Aug 10, 2007 | 07:25 AM
HondamanXxX's Avatar
GO GIANTS!
Default Need Help guys- ECU
I have a OBD2 JDM GSR into a EJ8, 98 ex. I am unsure what ECU to use. Keep in mind that later I will be puting Neptune in it when I boost it. Should I go with a OBD1 ECU p28?
I am very clueless when it comes to ECU's. I would like to stay OBD2 also.
Old Aug 10, 2007 | 07:35 AM
TheWickedOne's Avatar
Use the OBD1 P28... scrap the OBD2 ECU ..
Old Aug 10, 2007 | 07:40 AM
GO GIANTS!
Default Re: (TheWickedOne)
Another questions. Can I have the p28 chipped and still be able to add Neptune later or should the ECU be virgin?
Old Aug 10, 2007 | 07:59 AM
Default Re: (HondamanXxX)
Depends... Which version of Neptune ? RTP ?
If you have a virgin P28 and have the 28 Pin Dip socket soldered in, its typically not recommended to desolder the socket. Since you'd be applying heat not only one time but four times - The chances of burning a track or damaging the ECU is likely unless you take it to a professional that has a good soldering iron station.
just my .02 cents
MurtazaDSM
Engine Management and Tuning
Dec 23, 2010 08:25 PM
NO_FEAR_LWO
Aug 22, 2006 04:10 PM
hYbRid_Eg6
Jul 31, 2005 09:36 PM
Euro98ITR
Feb 7, 2005 01:04 PM
