speedo
Hi I'm trying to fix my sisters 97 civic cx the speedo needle does not work. So I changed the vss sensor, but it didn't help the needle gets to 30kmh the gets stuck then other times the needle will work fine, its as if there is a faulty wire or sensor any ideas????
swap out the cluster with your own if possible or borrow someone else's and see what happens, Im guessing its a broken spring in the speedometer and you need to replace the unit. By swaping it out you'll eliminate that from faulty wiring.
duneracer69
Nov 6, 2005 06:50 PM
speed.freak
Jun 8, 2005 01:40 PM
