Help, Rattle or buzzing coming from under car, heat shield?
Old Sep 12, 2005 | 08:56 AM
S2KILLA's Avatar
From: Yeah IM from Jersey, big wup, wanna fight about, it, USA
Default Help, Rattle or buzzing coming from under car, heat shield?
Ok I did a quick archive hunt to find out if some of the symtoms were happening to my car. Ok at 3000-3300 rpms a buzz will be produced either during acceleration of deceleration. It has the sound of a circular saw going through wood. Thats exactly how to describe it. I just bought a full exhaust, header and cat and am waiting to have it put on. Will this solve the problem. Obviously if it is the cat, it will, but if its not the cat, what could it be?
Thanks
Old Sep 12, 2005 | 10:49 AM
S2KILLA's Avatar
Default Re: Help, Rattle or buzzing coming from under car, heat shield? (SupersonicBlueGSR)
im going to drive it again in a lil bit, it might even be coming from the engine compartment. Ill keep everyone posted.
Old Sep 12, 2005 | 11:15 AM
JDMoMo
Guest
Posts: n/a
ok, is it coming from the bottom of the car or under the hood?
If it's the bottom, then it's the cat convertor head shield - and if it's from under the hood, then its the shield for your header.....I had problems w/ both, both were loose so I fixed it. Oh, also, you might need a washer for your cat convertor. It goes between your header and the cat convertor. Mine wore out so I needed one. Tell me if that helps
Old Sep 12, 2005 | 11:19 AM
S2KILLA's Avatar
Default Re: Help, Rattle or buzzing coming from under car, heat shield? (JDMoMo)
will do
Old Sep 12, 2005 | 12:04 PM
97tegGS's Avatar
Yea. I would definately check your heat shields or other exhaust componets. The vibration for the exhaust can make it sound horrid.
I believe its multiple 10mm bolts. I don't even have mine on anymore.
Old Sep 12, 2005 | 12:16 PM
JDMoMo
Guest
Posts: n/a
Default Re: (97tegGS)
BTW, i've taken out all my heat shields, even the one for the cat convertor...i didn't facee any problems yet...
Old Sep 13, 2005 | 10:11 AM
S2KILLA's Avatar
Default Re: (JDMoMo)
It does sound horrid. I cant stand it. I try to rev on some lil hunnies and as soon as it goes to 3 grand they all run cuz it sounds like a chainsaw. ****!!!
Old Sep 13, 2005 | 10:58 AM
JDMoMo
Guest
Posts: n/a
Default Re: (SupersonicBlueGSR)
LOL. ok u said 3000rpm, that's the key. It's ur heat shield. Same thing happened to my car. It was loose. also the one for ur cat. Tighten both and ur good to go. Man it'll take u like 10 mins. Stop scaring sexy *** fine hunnies and make them love you with the sound-free ride
Old Sep 14, 2005 | 09:18 AM
S2KILLA's Avatar
hahaha i will try this, i get off of work in 2 hours so ill let u know. its just the 4 bolts on the piece of scrap metal. it sounds sooo dumb to tighten them because on sunday im puttin on my whole exhaust. but i cant stand it enough for even one more minute
Old Sep 14, 2005 | 11:04 AM
JDMoMo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">hahaha i will try this, i get off of work in 2 hours so ill let u know. its just the 4 bolts on the piece of scrap metal. it sounds sooo dumb to tighten them because on sunday im puttin on my whole exhaust. but i cant stand it enough for even one more minute</TD></TR></TABLE>
Well, ur not changing the IM and the cat converter right? If not then just tighten them but if ur going to replace everything then u might as well do it on Sunday.
Old Sep 14, 2005 | 11:13 AM
S2KILLA's Avatar
Yeah everything my man. I cant wait!!!
Old Sep 14, 2005 | 11:20 AM
dynamo's Avatar
I have had this exact problem before (twice) and most likely the resonator on your midpipe is broken. I have had to replace this twice on my civic in the past, and the symptoms were dead on to what you are describing. I was able to fix it by replacing the midpipe with a stock one. HTH
Old Sep 15, 2005 | 04:02 AM
JDMoMo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SupersonicBlueGSR &raquo;</TD></TR><TR><TD CLASS="quote">Yeah everything my man. I cant wait!!!</TD></TR></TABLE>
Perfect, dont' waste ur time then. Just do it all together on Sunday. You can live w/ it for 3 days...I did for a year
Old Sep 15, 2005 | 07:45 AM
S2KILLA's Avatar
hahahahahaha u lazy ****. JK But I tightened the ones on the header, but it def sounds like its under the car now, it is god aweful, Im going to take a ****** hammer to the midpipe when I take it off.
sitinduk
Jan 31, 2008 06:17 PM
97ek9
Nov 5, 2007 08:20 AM
98R-1144
Jun 13, 2006 02:01 PM
JoshRambo
May 4, 2003 09:32 AM
onyx00
Jul 21, 2002 06:38 PM
