HARD TO SHIFT IN OR OUT OF GEAR
Old Sep 11, 2005 | 07:48 PM
num1rbffan's Avatar
Default HARD TO SHIFT IN OR OUT OF GEAR
It all started the other day. I was racing and I let off the clutch to quick and grinded 3rd gear. Then I started to have problems get in and out of all gears. It doesn't strach or anything like that but man it is hard as heck to get in or out of gear. Does any one have any suggestions on what is wrong. Stock tranny, stock linkage B&M Pro Edge short throw shifter.
Old Sep 11, 2005 | 08:01 PM
pubestripe's Avatar
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (num1rbffan)
well, either your clutch is fucked, or you are just due for a fluid change. we need more info on the tranny. is it a stock clutch? when was the last time you changed the mtf? and that is what you get for having a short shifter, those put un-needed stress on our trannies which were not made for fast race shifting...
Old Sep 11, 2005 | 08:09 PM
num1rbffan's Avatar
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (pubestripe)
It is a stock clutch and stock b18c trannie. I just got the car a year ago and not sure when mtf was changed so I could probably start off there. And it is kind of selective because sometimes are a LOT harder to shift in and out then others and I don't think the clutch is bad becaue I just replaced the master and slave cyclinder about 9 month ago and they said the clutch looked good.
Old Sep 11, 2005 | 10:16 PM
Greddy Dantegra's Avatar
OMNI-POWER QUICKLUTCH CLUTCH MASTER CYLINDER! I've got the same problem... i can't get into gears it would be stiff *** hell, i have to rev match it in order to get into gears... This only happens when i'm in the high rpms... at low rpms i get into gear alot easier but still stiff!!! i just order a omnipower master cyclinder i heard it would fix the problem... and with a short shifter you definately need a performance master cylinder.... i also ordered a new shift linkage... imma try to see if it works if not than i would try to take out my tranny...
Old Sep 12, 2005 | 12:49 AM
bonta-kun's Avatar
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (dvs gsr)
im having the same problems right now
some say its the clutch....
some say its the mtf......
well tommorw ima inspect the Clutch master cylinder and the Clutch Slave Cylinder make sure their not leaking and that it has fluid and then change the tranny fluid (gm synchromesh friction modified) then if nothing then its gonna be the clutch
you should try these same steps ill let u know how mine works out
Old Sep 12, 2005 | 04:00 AM
JDMoMo
Guest
Posts: n/a
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (I got sole....)
yea, good thing is to get it inspected from a shop. They'll charge but it's a lot better to find what actual problem is before you change anything. Once you kno what it is, then buy that. Since there are so many things that can be wrong. Same thing happened to my GSR Tranny. I changed the clutch actually, it worked but it might not be the same for you. I also changed the slave/master cylinders for my clutch once before but that didn't really do anything for me but it's good since my car that time had 140K anyway. Though, now I have a brand new Type R tranny w/ LSD from the dealer I love it! But yeah, I'd go with your clutch, depending on when it was changed last or if it has at all. Probably 85% of it being the clutch.
Also, let me say this, it might be true or not but short shifters will mess up your tranny. I forgot exactly why that is but I was going to put it on but some of the guys said I shouldn't mess with it. So I think you might be better off short shifter. Discuss w/ others though if I am correct or not. Good luck man
Old Sep 12, 2005 | 04:40 AM
LSracing94's Avatar
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (JDMoMo)
its most likely your clutch..there is like 93285172451 threads on this
the grind could be due to a bad synchro also
Old Sep 12, 2005 | 06:20 AM
95lstegman's Avatar
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (LSracing94)
do these things, and tell me if it's difficult to shift or you get a grind in each case:
1) sitting with the car off, put it into third gear
2) sitting with the car on but still, put it into third gear
3) driving down the road at 20mph, engine idling, put it into third gear
4) shift from second to third at 20mph
5) shift from second to third at 45mph
tell me which of these situations cause a grind or diffucult shift and i'll tell you what's wrong.
Old Sep 12, 2005 | 07:21 AM
JDMoMo
Guest
Posts: n/a
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (95lstegman)
<-----Believes what this guy's saying!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">do these things, and tell me if it's difficult to shift or you get a grind in each case:
tell me which of these situations cause a grind or diffucult shift and i'll tell you what's wrong.</TD></TR></TABLE>
LOL You da man
Old Sep 12, 2005 | 09:34 AM
num1rbffan's Avatar
95lstegman when you are telling me to shift gears do you mean with the cluctch pressed in on all the step?
Old Sep 12, 2005 | 09:38 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by num1rbffan &raquo;</TD></TR><TR><TD CLASS="quote">95lstegman when you are telling me to shift gears do you mean with the cluctch pressed in on all the step?</TD></TR></TABLE>
i think that's your problem... you need to press the clutch in to change gears
Old Sep 12, 2005 | 09:44 AM
JDMoMo
Guest
Posts: n/a
Default Re: HARD TO SHIFT IN OR OUT OF GEAR (da_truf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by da_truf &raquo;</TD></TR><TR><TD CLASS="quote">
i think that's your problem... you need to press the clutch in to change gears </TD></TR></TABLE>
LOL
Old Sep 12, 2005 | 09:45 AM
num1rbffan's Avatar
Actually o'smart one you can shift gears with out using your clutch with out grinding if you know what you are doing
Old Sep 12, 2005 | 09:46 AM
95lstegman's Avatar
yes, you must always fully depress the clutch in order to shift. if you want to be a three-pedal pimp like me, use your right foot to gas and brake at the same time. much better for the car than trying to clutch and brake at the same time.
Old Sep 12, 2005 | 10:01 AM
be.twenty's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by num1rbffan &raquo;</TD></TR><TR><TD CLASS="quote">Actually o'smart one you can shift gears with out using your clutch with out grinding if you know what you are doing</TD></TR></TABLE>
yes, i know that. but can you do it with the car parked and running .. have fun trying
Old Sep 12, 2005 | 03:27 PM
num1rbffan's Avatar
95lstegman-
Pretty Much they are all of them are not as easy as they should be. third is about the hardest and 2nd and Reverse are about the easiest.
Old Sep 12, 2005 | 05:15 PM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by num1rbffan &raquo;</TD></TR><TR><TD CLASS="quote">95lstegman-
Pretty Much they are all of them are not as easy as they should be. third is about the hardest and 2nd and Reverse are about the easiest.</TD></TR></TABLE>
regarding . . . which/what?
Old Sep 12, 2005 | 06:33 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You revved the engine high and now it's very hard to shift. Same thing happened to me at the end of my original clutch's life.
Problem is that either one of the clutch hub springs or a piece of metal near the spring comes out or gets dislodged and jammed in there somewhere, and prevents the clutch from fully disengaging, making it hard to move the shifter.
You'll have to replace at least the clutch disc. If you're still on the original clutch or it's been at least 50K miles I would probably just go ahead and change out the whole thing including the pressure plate. Make sure you replace the throwout bearing, and also you'll need to have the flywheel resurfaced, unless you'd like to change that out for a lighter flywheel also (which is what I did, also so I wouldn't have days of down time).
Old Sep 12, 2005 | 07:38 PM
95lstegman's Avatar
Default Re: (PatrickGSR94)
hey, pat's got a new avatar. haven't seen you around lately, BTW
Old Sep 13, 2005 | 04:56 AM
Community Builder
Default Re: (95lstegman)
heh yeah I've been around, I even made a post from one of the hotels when I was in Europe a few weeks ago.
Old Sep 13, 2005 | 11:08 AM
JDMoMo
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PatrickGSR94 &raquo;</TD></TR><TR><TD CLASS="quote">heh yeah I've been around, I even made a post from one of the hotels when I was in Europe a few weeks ago. </TD></TR></TABLE>
So u been around ehh?? Posting from hotel rooms...hmmm
dc2long
Mar 27, 2011 09:47 AM
Bhoang
Honda Civic (2001 - 2005)
Apr 13, 2010 02:18 PM
ohiohonda
Feb 21, 2006 11:11 AM
dohcdelsol
Jan 7, 2005 10:11 PM
Jesse H
Aug 20, 2002 05:04 PM
