do u know what to do....
Old Sep 11, 2005 | 09:12 PM
hamburgler's Avatar
Default do u know what to do....
ok i have a problem and i thought someone might know what to do.ok i lowered my back went fine.when i got to the front i could fit the spring compresser in the spring.the compresser came from autozone.i have tried everything to get it in to hammer sideways ect.........i didnt know if anyone else had this prob on there integra.its a 95 if that makes a diff.is there a diff kind of sping compresser out there ............
thanks,cory
Old Sep 11, 2005 | 09:16 PM
DAguyLS's Avatar
you didn't even state your problem
was it that you couldn't get the fronts compressed?
Old Sep 11, 2005 | 09:18 PM
hamburgler's Avatar
Default Re: (DAguyLS)
i couldnt get the sping compresser in the spring the coils were to close to fit or slid them in
Old Sep 11, 2005 | 09:19 PM
DAguyLS's Avatar
now explain what kind of compressor you bought/rented.
Old Sep 11, 2005 | 09:22 PM
hamburgler's Avatar
whatever one u get from autozone............has two thing u slid in the coils and compress it with a large bolt..........
Old Sep 11, 2005 | 09:24 PM
Integra_drk's Avatar
Default Re: (carless87)
you might just have to get a diff compressor, try checker auto parts. got mine from there and worked fine on the front. The clamps might just be thinner on a different one.
Old Sep 11, 2005 | 09:28 PM
DAguyLS's Avatar
I did my fronts on my last EG with ones like your talking about. I had no problem doing it.
So i'm not really sure how to help you.
TimeAttackFreak's Avatar
you could put roughly about 80 zip-ties around the top and bottom coils , face the top into a trash can and wrench away... besure to wear safety goggles.... but you do so at your own risk. we did that once , it held but it was scary.
Old Sep 11, 2005 | 09:32 PM
hamburgler's Avatar
Default Re: (donutz)
ok but how am i to compress the new ones........zip ties again
Old Sep 11, 2005 | 09:35 PM
well, depending how much lower they are, you dont have to compress them, they just chill there until you put the car back on the ground. assuming its on jacks.
Old Sep 11, 2005 | 10:14 PM
hamburgler's Avatar
Default Re: (Integra_drk)
they r only a inch lower on the front
Old Sep 11, 2005 | 10:17 PM
DAguyLS's Avatar
they should go back in without using the compressor.
Old Sep 12, 2005 | 07:12 AM
95lstegman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DAguyLS &raquo;</TD></TR><TR><TD CLASS="quote">they should go back in without using the compressor.</TD></TR></TABLE>
practically all lowering springs do. i can't name any that don't.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by donutz &raquo;</TD></TR><TR><TD CLASS="quote">you could put roughly about 80 zip-ties around the top and bottom coils , face the top into a trash can and wrench away... besure to wear safety goggles.... but you do so at your own risk. we did that once , it held but it was scary.</TD></TR></TABLE>
you don't need the cable ties. i did that once, a long, long time ago . . . duck ***** fuka! haha
Old Sep 12, 2005 | 07:16 AM
memicah's Avatar
Default Re: (95lstegman)
LOL. I love the cable ties idea... I had never thought of that.
to the thread poster: i own the same compressor from autozone, and i have used it on my 97 teg and it worked fine... i do remember it being a somewhat tight fit though. my advice is to just keep trying... or find another compressor nothing beats having the right tools for the job
Old Sep 12, 2005 | 09:42 AM
temp's Avatar
Default Re: (memicah)
**** a spring compressor, use your hands
Old Sep 12, 2005 | 10:41 AM
allmotorteg_96's Avatar
Default Re: (temp)
you can take them to a body shop.
Old Sep 12, 2005 | 10:55 AM
JDMoMo
Guest
Posts: n/a
Default Re: (allmotorteg_96)
speaking from experience.....
if you aren't gonna use those springs, all u do is cut it off. That's what I did.
I took a grinder and cut the spring, took me about 30 sec....
Front ones are a bitch because of the upper control arm....just do that. I promise you'll save a lot of time and effort. Good luck
****OH YEAH, DO NOT DECOMPRESS THE SPRING WHILE IT'S STILL IN. OR DO NOT UNBOLT IT FROM THE TOP EITHER. YOU'LL BE SCREWED****
Old Sep 12, 2005 | 12:01 PM
97tegGS's Avatar
Just set it on the floor put your foot or it and loosen. The newer integras will go about 30-40 yards while the older accords and civics go about 10-15.
Or just take it to sears or something and have them take it off for a few bucks.
Old Sep 12, 2005 | 01:40 PM
JDMoMo
Guest
Posts: n/a
Default Re: (97tegGS)
just cut that **** in half man. telling u, it works just fine.
Old Sep 12, 2005 | 02:19 PM
Sam92Teg's Avatar
Default Re: (JDMoMo)
I just wrapped towels around mine when I swapped in some springs. It isn't really under that much pressure and is fun trying to predict which turn of the wrench is going to pop. Its kinda like when you open a can of bisquits, lol. Wrap the towel so the only thing sticking out is the little nut and shaft, and keep your foot on the spring. I did have to put considerable effort getting the 1.8 inch drop springs back in, so 1 inch drop springs you will probably need another person to start the nut back on while you compress the spring with your hands.
Old Sep 12, 2005 | 02:51 PM
rkrone's Avatar
Default Re: (Sam92Teg)
i have heard that the towel method works... the fronts didn't fit in my compressor from autozone...(but hey, its a free rental) i just used a few c-clamps to move it a little and had a few friends help hold it in place
Old Sep 12, 2005 | 04:50 PM
stocker2shocker91's Avatar
I requested a short story for a title.
Default Re: do u know what to do.... (carless87)
yes i lowered my 91 teg with that same thing from autozone. It is a huge bitch to get those little things inbetween the coils, but keep at it or try sprayin a little wd40 or something on it. you wont need them for the new springs.
Old Sep 12, 2005 | 05:05 PM
95lstegman's Avatar
Default Re: do u know what to do.... (stocker2shocker91)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97tegGS &raquo;</TD></TR><TR><TD CLASS="quote">Just set it on the floor put your foot or it and loosen. The newer integras will go about 30-40 yards while the older accords and civics go about 10-15.</TD></TR></TABLE>
second best post of the day!
Old Sep 12, 2005 | 05:52 PM
temp's Avatar
Default Re: do u know what to do.... (95lstegman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95lstegman &raquo;</TD></TR><TR><TD CLASS="quote">second best post of the day! </TD></TR></TABLE>
mine was the first
Old Sep 12, 2005 | 06:13 PM
JDMoMo
Guest
Posts: n/a
Default Re: do u know what to do.... (temp)
yeah, LS is just following me around today....whatever post I'm in, he tries to follow me in it.
