b16 swap into 96 civic.......wiring help needed
Old Sep 10, 2005 | 04:33 PM
ITR.#1446's Avatar
Default b16 swap into 96 civic.......wiring help needed
What wiring harness should i use that would be the easiest. I have 2 99-00 harness both auto and i cant get them to work. I also have a obd2 p2t ecu and a obd1 p30 that came with the motor. What would be the best way to have the engine wired up. I have the motor in and everything ready to go but the harness and ecu.
Old Sep 10, 2005 | 04:35 PM
slomofo's Avatar
GDD Member
Use your stock harness, wire in VTEC and get an OBDII-A ECU then you're done.
Old Sep 10, 2005 | 04:39 PM
ITR.#1446's Avatar
Default Re: (slomofo)
the car was a shell so i had to rebuild and get everything so i should get a 96 ex harness then? what kinda ecu should i run?
Old Sep 10, 2005 | 04:43 PM
slomofo's Avatar
GDD Member
Run the 96 EX harness, then wire in knock sensor and it'll be fine on the motor. Either get an OBDII P30, a 96-97 P72 (You'll have IAB codes), 96-97 P73, or use the stock 96 EX ECU. If you want, you could get an OBDI jumper harness and it'll open up a whole new world of ECU's that you can use.
Civ-dx-96
10
Feb 28, 2013 04:15 PM
Azxster
Sep 6, 2007 03:25 PM
ITR.#1446
Sep 10, 2005 10:51 PM
turboed4life
14
Mar 27, 2004 07:40 AM
kamikaze258
Sep 3, 2002 09:50 AM
