NEED HELP GETTING A HARNESS FOR MY 96 DOING A B16 SWAP DOES ANYONE CUSTOM MAKE HARNESSES PREFFERABLY
anyone no how to convert a stock harness o no where i get the info to do so or anyone or a company that does it......anything let me know
Mr. Badwrench
Re: NEED HELP GETTING A HARNESS FOR MY 96 DOING A B16 SWAP DOES ANYONE CUSTOM MAKE HARNESSES PREFFER
it is easy to use the harness but if you dont want to do any wiring, but the bare minimum, get a 96-98 ex harness it is the easiest way to go. me, i would save the 400 bucks and use the harness you have. search you will find what to do. it is easy.
Former Moderator
Here's a thought:
WHY DON'T YOU TELL US EXACTLY WHAT CAR YOU HAVE, EXACTLY WHAT ENGINE YOU ARE TRYING TO RUN IN TERMS OF OBD, AND WHAT ECU YOU INTEND ON RUNNING?
Oh and turn off your caps lock button when starting a topic.
its a 97 civic ex...running a b16.....what modifications do u have to do to the EX harness to make it work
Solbros Owns Me
run a knock sensor wire, and maybe extend a plug here or there.
What ecu are you going to run?? You may need an adapter harness also
where you located at my boss does harnesses he could do yours in no timehe converted mine from single cam non vtec to lsvtec in no time
Former Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by madcatz23 »</TD></TR><TR><TD CLASS="quote">its a 97 civic ex...running a b16.....what modifications do u have to do to the EX harness to make it work</TD></TR></TABLE>
Jesus what kind of B16A is it? First Gen? Second Gen? JDM? USDM? B16A3? B16A2? What ECU?
One more vague-*** post and this one gets a lock.
We cannot help you unless you tell us EXACTLY what the hell you're starting with bro.
i am located in san jose, ca....its a complete swap i purchased out of a 2000 si, and i would be running the stock ecu for now....all i got is a few bolt ons for it. and i got my stock 97 ex harness.....so what modifications do i need....thanks for everyones help.....
oh and i did a auto to manual conversion......so do i need a ex manual wiring harness?????i got one locally i can get, just need to know what mods to do to it
ok so u got a B16a2 swap. If the B16 came with a wiring harness u can use that. otherwise you can use your stock harness plug it all up. If you dont want to wire up a knock sensor id get a obd2- obd1 harness and run a chipped p28. or if u want to wire in the knock sensor use the Si computer
okay bad news here...all i got is my stock harness......can i just run the vtec wire and a p28 so i dont need to run the knock any other provisions????
36Chitownrunnin
06-09-2008 09:28 AM
ITR.#1446
09-10-2005 10:51 PM
