vtm wire for vafc 2
Thanks to the craptastic instructions apex supplemented me with my vafc2, this piece of equipment has been rendered useless for over a year. Me and my friend have spent countless hours trying to figure out what was wrong and installed/uninstalled the vafc2 many times. The problem was that vtec wouldn't work and while in vtec, the cel would come on. If you look in the manual for b18c5, they dont even have that engine code in their wiring diagram. On top of that the diagram they do have for b18c isn't the same harness layout as the 01 type r's.
After doing some research I found out that the vtm wire has to be wired in for vtec to work properly. My question is where does this wire go? How do I wire this in, splice in with the current wire or wire it in and cut?
Here is a diagram I found that looks exactly like my ecu pinout.
On this website, it says on connecter c to plug it in number 10, would that be correct?
Im anxious to finally get this vafc2 working properly and take it to get it dyno tuned.
I can't help with your wiring question - but I had the exact same issue. The first tuner failed to install the CEL and I was having trouble and CELs for a long time before I figured out what was going on and got it fixed. Good luck.
Yes, VTM is for your oil pressure switch.
Cut that wire. And connect the VTM wire to the end of the wire that goes into the ECU. Tape up the other end as it will not be needed anymore.
k so ... i have the 1st GEN VAFC and i have the VTM sensor ... well i cant find the actual lead from the car... im assuming its the same color as the wire i have which is white with a blue stripe?
chrisir19
Sep 23, 2003 08:42 AM
