help wire up my VAFC
Old Feb 4, 2003 | 03:02 AM
Type RS's Avatar
Default help wire up my VAFC
alright i had a quick question about two wires on the ecu side. the vtec solenoid signal and the pressure sensor wire. the manual says to cut the wire going to the ecu and the connectors and then it explained which side should have the male/female connectors. this is were i got confused. what i got from it is that i cut the wire and connect one wire to the side still connectod to the pin and the the other wire connected to the car side. is this correct? if i confused someone please explain this in your on words.
Old Feb 4, 2003 | 07:48 AM
IN VTEC's Avatar
Default Re: help wire up my VAFC (Type RS)
The VAFC is in-line (in series) for those two.
Reread the diagram and connect the wires just as it says for your application.
Old Feb 4, 2003 | 07:57 AM
nolimits's Avatar
Correct!
Old Feb 4, 2003 | 08:04 AM
Type RS's Avatar
Default Re: help wire up my VAFC (nolimits)
Correct!
excellent i'm gonna finish installing it today. thanks for the help
Old Feb 5, 2003 | 02:27 AM
Type RS's Avatar
finished wiring it up last night. that **** works like a charm. it was pretty easy only took me about 30 minutes. thanks for the help.
b18c1995
Nov 27, 2004 01:03 AM
aces1980
Aug 1, 2004 10:05 AM
chrisir19
Sep 23, 2003 08:42 AM
Accord_Munch
Dec 5, 2002 06:36 AM
