distributor
Old Sep 9, 2005 | 11:58 AM
Malakai's Avatar
Default distributor
this may be a stupid question but will a distributor cap and rotor and wires from a d series work on a b series?
Old Sep 9, 2005 | 01:53 PM
Malakai's Avatar
Old Sep 9, 2005 | 02:00 PM
Kyles ej1's Avatar
Default Re: (Malakai)
i know the wire will for sure, dunno about the cap and rotor
Old Sep 9, 2005 | 02:06 PM
clm's Avatar
clm
Default Re: (93ejay1)
I think it depends on which B-series.
Old Sep 9, 2005 | 03:36 PM
EGmikeH22's Avatar
* B A N N E D *
too bad wires will not...
the height from the plug to the valve cover is different. and the dizzy won't fit either.
good luck
Old Sep 9, 2005 | 03:54 PM
Kyles ej1's Avatar
Default Re: (EGmikeH22)
too bad the wires do....my friend had d series on his gsr
Old Sep 9, 2005 | 03:56 PM
Malakai's Avatar
k, thanks anyways
Old Sep 9, 2005 | 04:00 PM
dantastic's Avatar
the cap and rotor should swap over in some cases... i used a d15b8 cap and rotor on my b16a.
Old Sep 9, 2005 | 04:46 PM
Malakai's Avatar
well im going from a d16y7 to a b18b
Old Sep 9, 2005 | 04:50 PM
HondaFanatic708's Avatar
From: San Diego, I miss Chicago, but love SD, CA, US of fuckin A
All of the internal components of the dist will swap over. The actual housing that attaches to the head will not because the mounting holes are positioned differently. I had to use all the internal components off my D-series dizzy on my B16A swap because the dizzy on that was gutted. Worked and still works fine. They may not work between OBDs though, like OBD1 dizzy components in an OBD2 dizzy, but I doubt this is the case. And when I say I used all the internals I mean all of them, not just the cap and rotor.
Old Sep 9, 2005 | 05:04 PM
Malakai's Avatar
k thanks helps a bunch
db8gsr_teg
13
Mar 7, 2020 08:48 PM
1siccrx
Oct 15, 2012 09:03 AM
monalisa overdrive
Apr 19, 2004 09:07 PM
Casey
Jul 28, 2003 02:15 PM
J.R.
May 30, 2002 04:05 PM
