identifying an LSD.
Old Sep 8, 2005 | 01:23 PM
gunnis's Avatar
Default identifying an LSD.
Hey,
I am in the middle of buying a swap. The motor originally came equipped with a stock lsd trans. it was swapped out due to a grind and replaced with apparently a GSR trans equipped with an LSD.
My problem:
the tranny is not stamped "LSD" so either its aftermarket,or an oem diff was installed on an originally non lsd tranny.
So...i beleive by jacking up the car and spinning the wheels there is a way to identify if there is a LSD present by which way the wheels spin..please correct me
Thanx in advance for the help
Luserkid's Avatar
Default Re: identifying an LSD. (gunnis)
Take off an axle and see if it has it or not.
Old Sep 8, 2005 | 01:25 PM
gunnis's Avatar
Default Re: identifying an LSD. (Luserkid)
the motor is currently in a car.....not my own either. i am looking for easier alternatives untill i can pull the trans, and inspect it myself.
Old Sep 8, 2005 | 01:29 PM
Marauder's Avatar
If you spin a tire , the other one should spin the same direction. Open diffs usually spin the tires in opposite directions.
Old Sep 8, 2005 | 03:23 PM
Audi RS4's Avatar
Lover
Take both axles out and look for a small bar going thru the middle. I believe if it has one it is not LSD... damnit i can't remember... someone back me up
Old Sep 8, 2005 | 04:36 PM
gunnis's Avatar
Default Re: identifying an LSD. (Carparts-Auction.com)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Carparts-Auction.com &raquo;</TD></TR><TR><TD CLASS="quote">Take both axles out and look for a small bar going thru the middle. I believe if it has one it is not LSD... damnit i can't remember... someone back me up
clearly you didn't take the 30 seconds to even read this thread. i am fully aware what to look for when the axels are NOT present. this car is in-tact,working and driving on a daily basis.
thanx Marauder, this was what i had in mind but wanted to clarify.
Old Sep 8, 2005 | 05:10 PM
Heylookits shawn's Avatar
there is no way to tell without looking through the diff. i have a usdm itr tranny in my car and the wheels spin in opposite directions. and i KNOW for a fact it has an lsd becuase i have seen it with my own eyes.
Old Sep 8, 2005 | 06:16 PM
john99's Avatar
if you pull the axles out you should be able to see right through one side of the diff to the other, if it is NON LSD there will be a rod going through the diff. If the motor is already installed. simple jack up both front tires, turn the wheel either clockwise or alternate, and BOTH wheels should be spinning in the same direction. easy fix
Old Sep 8, 2005 | 06:35 PM
JdmLub's Avatar
Default Re: identifying an LSD. (john99)
[/QUOTE]
My problem:
the tranny is not stamped "LSD" so either its aftermarket,or an oem diff was installed on an originally non LSD tranny.
[/QUOTE]
I bought a Del Sol front clip from by buddies importing shop, came with a B16a gen2 and the tranny is stamped LSD, i am on a boat right now(Navy) so i cant (rember) look at it......is mine LSD???
Old Sep 8, 2005 | 07:53 PM
95civickid's Avatar
so from the way i understand is that your buying the swap and not the car. correct?
so if you have the money and your really interested in it tell him. so then he pulls the motor you look through the tranny if you see straight trough it then its LSD but if theres a bar going through it then its not LSD. then your not abligated to buy it because he lied.
but if your buying the car then all you have to do is do a nice burnout if it leaves 2 tire lines then its LSD but if it only 1 tire line its not LSD. or take a corner fast you should be able to feel the LSD kicking in.
CADC2
Jan 17, 2009 02:20 PM
b17eg
Jul 10, 2007 06:41 AM
98oRange
Apr 8, 2005 06:45 PM
vteg97
Mar 6, 2004 02:53 PM
93b18civic
May 5, 2002 03:19 PM
