Which Iridium plug????
Denso Iridium plug 5304 IK20 $11.99
NGK IX iridium 3764 BKR6EIX-11 0.044 $6.95
NGK Iridium plug 6741 IFR6E-11 0.044 $11.71
Anyone know why the IX plug is so much cheaper than the others? I need some new plugs for the beater, so thought I would get some for the R also.
i have used the Denso IK20 in the past but only bc they were free
i noticed no difference over the $1 champions that were in the car prior to that
yea, when i was trying to find new plugs yesterday, all the autoparts stores said the only one factory replacement for the R was the NGK R laser something. whatever it was, it was going to be over $40 for new plugs. I decided not to get new ones
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR »</TD></TR><TR><TD CLASS="quote">NGK coppers. $10 bucks for a set. Replace them every other oil change, and you're good to go
I was thinking about that, but it seems more expensive. Let's say the set of the iridiums going to cost me $50 after shipping, but last 30k. If I use the $10 set every 3k, that's going to be $100 worth of plugs by the time I hit 30k making them twice as expensive correct?
</TD></TR></TABLE>I was thinking about that, but it seems more expensive. Let's say the set of the iridiums going to cost me $50 after shipping, but last 30k. If I use the $10 set every 3k, that's going to be $100 worth of plugs by the time I hit 30k making them twice as expensive correct?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 »</TD></TR><TR><TD CLASS="quote">
I was thinking about that, but it seems more expensive. Let's say the set of the iridiums going to cost me $50 after shipping, but last 30k. If I use the $10 set every 3k, that's going to be $100 worth of plugs by the time I hit 30k making them twice as expensive correct? </TD></TR></TABLE>
I was exaggerating a bit on the changing cycle. They are good for 15-20k miles usually. I change mine a bit more often due to track days and occasional tuning.
the BKR7EIX's are great. still in good shape after about 20k miles.
the only reason i swapped them out is because i had to upgrade to an 8 heat range.
i dont think the extra $6 per plug is going to break the bank
W95civicEXcoupe
30
May 3, 2015 03:07 PM
DJNauTicz
Feb 5, 2007 07:54 AM
RACEPAK
Sep 21, 2005 04:08 AM
