Which Iridium plug????
Old Sep 8, 2005 | 11:39 AM
Jowee's Avatar
Default Which Iridium plug????
Denso Iridium plug 5304 IK20 $11.99
NGK IX iridium 3764 BKR6EIX-11 0.044 $6.95
NGK Iridium plug 6741 IFR6E-11 0.044 $11.71
Anyone know why the IX plug is so much cheaper than the others? I need some new plugs for the beater, so thought I would get some for the R also.
Old Sep 8, 2005 | 11:48 AM
Bbasso's Avatar
Default Re: Which Iridium plug???? (Jowee 1162)
Your search for Iridium returned 18 results.
Old Sep 8, 2005 | 11:49 AM
Jowee's Avatar
Default Re: Which Iridium plug???? (Bbasso)
I know Rob, but none of them go into specifics on why one is better than the other.
Old Sep 8, 2005 | 11:50 AM
BlueR's Avatar
i have used the Denso IK20 in the past but only bc they were free
i noticed no difference over the $1 champions that were in the car prior to that
Old Sep 8, 2005 | 02:31 PM
MOVE OVER's Avatar
Default Re: Which Iridium plug???? (neo_)
yea, when i was trying to find new plugs yesterday, all the autoparts stores said the only one factory replacement for the R was the NGK R laser something. whatever it was, it was going to be over $40 for new plugs. I decided not to get new ones
Old Sep 8, 2005 | 03:01 PM
mugenracer's Avatar
I'm using denso IK22's, i had IK20's in before and noticed no difference in the two sets. I also tried HAMP VK22's which are just rebaded IK22's.
Old Sep 8, 2005 | 03:35 PM
ultimatehonda's Avatar
I have NGK IX iridium. Did not feel a difference from the stock plug.
Old Sep 8, 2005 | 03:41 PM
92TypeR's Avatar
FSAE
Default Re: Which Iridium plug???? (ultimatehonda)
NGK coppers. $10 bucks for a set. Replace them every other oil change, and you're good to go
Old Sep 8, 2005 | 03:47 PM
Jowee's Avatar
Default Re: Which Iridium plug???? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">NGK coppers. $10 bucks for a set. Replace them every other oil change, and you're good to go </TD></TR></TABLE>
I was thinking about that, but it seems more expensive. Let's say the set of the iridiums going to cost me $50 after shipping, but last 30k. If I use the $10 set every 3k, that's going to be $100 worth of plugs by the time I hit 30k making them twice as expensive correct?
Old Sep 8, 2005 | 03:51 PM
WhoisDan's Avatar
I have NGK IX's
Old Sep 8, 2005 | 04:02 PM
RTW DC2R's Avatar
waste of $ IMO
I rock Vpower 6 and 7 range plugs and they work just dandy.
Old Sep 8, 2005 | 04:04 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jowee 1162 &raquo;</TD></TR><TR><TD CLASS="quote">
I was thinking about that, but it seems more expensive. Let's say the set of the iridiums going to cost me $50 after shipping, but last 30k. If I use the $10 set every 3k, that's going to be $100 worth of plugs by the time I hit 30k making them twice as expensive correct? </TD></TR></TABLE>
I was exaggerating a bit on the changing cycle. They are good for 15-20k miles usually. I change mine a bit more often due to track days and occasional tuning.
Old Sep 8, 2005 | 04:08 PM
JOHN WAYNE's Avatar
Default Re: (RTW DC2R)
the BKR7EIX's are great. still in good shape after about 20k miles.
the only reason i swapped them out is because i had to upgrade to an 8 heat range.
i dont think the extra $6 per plug is going to break the bank
W95civicEXcoupe
30
May 3, 2015 03:07 PM
RACEPAK
Sep 21, 2005 04:08 AM
pa2play
Jul 25, 2004 01:15 PM
