Fast Idle Thermo Valve - anyone NOT running one?
Old Sep 7, 2005 | 09:49 PM
2point2's Avatar
Default Fast Idle Thermo Valve - anyone NOT running one?
I think mine is busted. Do I really need this? what would be the result completely removing it and making a block off plate?
Thanks
Old Sep 7, 2005 | 11:09 PM
Hawkze_2.3's Avatar
Default Re: Fast Idle Thermo Valve - anyone NOT running one? (2point2)
People take them off or bypass them all the time. There's many threads about it...
Old Sep 8, 2005 | 12:11 AM
SnlpeR's Avatar
wont your idle be too low if you block it?
mines bypassed right now but still sucks in a little air even if the white plastic screw is screwed all the way in...
in fact...my idle is a lot lower now that i tightened it all the way
Old Sep 8, 2005 | 07:21 AM
jmcclell's Avatar
The car will run just fine without it.
Just block the two "in" and "out" holes underneath the throttle body with some silicone sealant.
Old Sep 8, 2005 | 10:00 AM
flyrod's Avatar
Default Re: Fast Idle Thermo Valve - anyone NOT running one? (jmcclell)
Mine is blocked off. If you just disconnect the coolant hoses, your idle will stay high.
Old Sep 8, 2005 | 10:07 AM
2point2's Avatar
Thanks guys.. i filled the vaccum holes with sealant and fabbed up a block-off plate for extra insurance.
Old Sep 8, 2005 | 11:42 AM
Lewdin' Incognito's Avatar
Default Re: (2point2)
To ask the dumbass question:
Why? What is this supposed to accomplish?
Old Sep 8, 2005 | 12:44 PM
specialedition's Avatar
Default Re: (Lewdin' Incognito)
it does not accomplish anything ... the FITV raises the rpm on the engine during cold starts to help warm the engine up to normal operating temperatures... I would not like to be without it. When the engine warms up a little thermo wax plunger plugs up the hole and the car idles at normal 750 +/- 50 rpms...
Old Sep 24, 2005 | 04:56 PM
Hatch_Back_97's Avatar
Default Help me too!
I have a 1997 Y8 (OBDII) with the OBD1 conversion ECU and harness, ever since doing this my cold starts sucks ***, cams liek a bitch (old hotrod sound) until about 10-15 seconds have passed and it smooths out some, but still lobes alot...what can I do?
Shadowcat
Sep 14, 2012 07:12 AM
namewasdallas
Oct 19, 2009 07:52 PM
Maxcapacity
Jun 10, 2008 06:11 PM
jetlude
Aug 1, 2006 11:09 AM
Chuji
Apr 12, 2003 12:11 PM
