Cruise cotntrol button removal...
Old Feb 26, 2002 | 07:08 PM
JasonNagra's Avatar
New User
Default Cruise cotntrol button removal...
I was just wonderig how you remove the cruise control button on 98 LS??? I ran a search and didn't come up with anything. I want to be able to cleanly remove it with no scratches or anything. Thanks in advance, Jason.
Old Feb 27, 2002 | 08:31 AM
FourDoorGSR's Avatar
Default Re: Cruise cotntrol button removal... (JasonNagra)
If you are talking about the cruise control button on the steering wheel. Then it is not possible to take it out without disconnecting your horn. The CC buttons are connected to the air bag real/harness. You can actually just take it out and have a big hole there where the CC buttons used to be, but not only are you sacrificing your CC but your horn as well.
Old Feb 27, 2002 | 06:56 PM
JasonNagra's Avatar
New User
Default Re: Cruise cotntrol button removal... (FourDoorGSR)
No. Im talking about the actual button you press and it turns on alittle green light on the dash on the left had side.
Old Feb 27, 2002 | 07:20 PM
rockwilda's Avatar
i was wondering this too, i want to replace it with a shift light
Old Feb 27, 2002 | 07:27 PM
BranzLS's Avatar
Default Re: Cruise cotntrol button removal... (da_rockwilda)
Are you talking about the button on the left hand side, opposite the guage brightness dial?? If you are, they can come out VERY easily. I popped mine out with a screwdriver. If you wanna do it a harder but possibly safer way, you can remove the front of the guage cluster, actually the box that sets the guages back by taking out the 2 top screws because the bottom of it simply snaps. The reach down, push on the sides and the whole cruise control button/pod pops right out. Then you need to disconnect the wiring which should just snap out. I took mine out to paint the ring around the button and I simply used a flat head screwdriver and my hands... hope this helps a little
Old Feb 28, 2002 | 07:26 AM
JasonNagra's Avatar
New User
Default Re: Cruise cotntrol button removal... (BranzLS)
Thank you that did work well. I used the taking out the gauge cluster method, i really was worried about scratching my dash. Both methods work fiine though.
Old Feb 28, 2002 | 11:54 AM
BranzLS's Avatar
Glad I could help... I am about to do something similar to it! Good luck with whatever you are going to put there.
Old Feb 28, 2002 | 12:10 PM
JL 74's Avatar
Why would you want to get rid of the cruise control button/cruise control?
Is this the same concept as the 1. clock removal 2. rear wiper removal ?
Old Feb 28, 2002 | 12:22 PM
GSRwBOOST's Avatar
Default Re: Cruise cotntrol button removal... (jl74)
no.. it's to help save weight.. j/k
i removed mine in favor of a boost gauge there..
Old Feb 28, 2002 | 12:54 PM
madchiller's Avatar
Premium Member
25 Year Member
Default Re: Cruise cotntrol button removal... (GSRwBOOST)
makes sense, just make it so its always on... i mean come on.. how many people here actually turn the button off anyway? and why would you?
Old Feb 28, 2002 | 12:56 PM
nerdish's Avatar
What did you have to do to get a boost gauge to fit? Like, isn't the hole in the dash pretty small compared to the gauge? How much did you have to trim, etc? Was it a bitch? Details!
What are you going to do if you sell the car, and want to put the cruise control button back in.. and now the hole is too big? Unless you never had to modify the hole in the first place.
Old Feb 28, 2002 | 01:29 PM
GSRwBOOST's Avatar
Default Re: Cruise cotntrol button removal... (FuknGSR)
you dont want to leave it on because it does draw vacume... part of the system draws vacume so it knows when your accelerating and decelerating.. if you have a vacume gague hooked up you will see it change a little.. and that means it's usinga little power.. so if you worry about being nickle and dimed to death with it... then just turn if off and leave it off...
Old Feb 28, 2002 | 01:30 PM
GSRwBOOST's Avatar
Default Re: Cruise cotntrol button removal... (nerdish)
dremmel that hole out until the gauge fits snug... and if your gonna put it back to stock?? well.. lets just say dont if you plan on getting rid of the car...
narab123
Honda Civic (2001 - 2005)
Dec 23, 2012 11:06 PM
goldenmustache
Feb 6, 2012 06:18 PM
erck
Oct 8, 2006 02:28 PM
preludepower
Oct 14, 2005 09:17 PM
Cynical 1
Jan 8, 2003 10:40 AM
