motor makin a tickin noise
Old Sep 5, 2005 | 11:59 PM
FROSTDC2's Avatar
Default motor makin a tickin noise
just got my 2nd gsr swap fully rebuilt, theres a tickin noise not too loud thought it was comin from the head, now i think it might be from the block, any ideas?? its an all motor gsr
Old Sep 6, 2005 | 04:17 AM
97CTR's Avatar
Default Re: motor makin a tickin noise (champ white coupe)
valve adjustment?
Old Sep 6, 2005 | 06:55 AM
FROSTDC2's Avatar
Default Re: motor makin a tickin noise (97CTR)
did two of them, still the same
Old Sep 6, 2005 | 07:01 AM
doublek's Avatar
Maybe you have a LMA thats sticking...i got that prob...does it constantly do it or does it click then go away and does it again? Also does it do it when the motor is cold?
Old Sep 6, 2005 | 09:05 AM
RudeBwaiSi's Avatar
I don't want to say its probably detonation. . .so I suggest rechecking all valves clearances and make sure nuts are tight. I had the same problem after adjusting valves, but I am thinking I didn't allow the motor to be dead cold.
Old Sep 6, 2005 | 09:16 AM
PURPLETERROR aka BIGMATT's Avatar
lost motion assy
Old Sep 6, 2005 | 09:32 AM
RudeBwaiSi's Avatar
Default Re: motor makin a tickin noise (PURPLETERROR)
If it is LMAs, what do you do to stop the sound?
Old Sep 6, 2005 | 06:25 PM
FROSTDC2's Avatar
Default Re: motor makin a tickin noise (RudeBwaiSi)
no lma is fine, any1 hear of forged pistons wiggling around a tiny bit? the bottom sleeves shrink a tiny bit?
Old Sep 6, 2005 | 06:27 PM
itralex's Avatar
did you soak the LMA's before for a couple of days before you installed them?
if not, then it will tick
Old Sep 6, 2005 | 06:44 PM
FROSTDC2's Avatar
Default Re: motor makin a tickin noise (itralex)
repeat.. head is not making the noise, it sounds liek pistons r tappin slightly, nothing major, it was drivin about 100 miles today and it feels great, no problems or anything, just makin a slight tickin sound
Old Sep 6, 2005 | 09:25 PM
FROSTDC2's Avatar
do forged pistons begin to make a "diesel" type noise?
Old Sep 7, 2005 | 07:01 AM
RudeBwaiSi's Avatar
Souinds like the same noise I was hearing after getting my valves adjusted. Exactly how it was idling like a diesel automobile.
Old Sep 7, 2005 | 07:36 AM
StErN's Avatar
Sounds like it could be your pistons making the noise. Does the noise go away when the motors warm? With forged pistons your most likely going to get a louder piston noise especially when the motor is cold, but it should go away once the motor is warm or at least the noise should get quieter.
Old Sep 7, 2005 | 08:08 AM
FROSTDC2's Avatar
Default Re: motor makin a tickin noise (StErN)
ya it quiets down but still makes the noise when it heats up, this is normal with forged pistons, i had cps and they didnt make this noise, i build my 2nd motor with wisecos and it does... hope everything is safe.. it sure rips
obuhmyuh
48
Feb 8, 2008 11:42 PM
2-logicl
20
Jun 21, 2006 03:53 AM
2-logicl
Jun 20, 2006 06:31 AM
b20vtech
Feb 20, 2006 01:07 PM
