i NeeD help taking off the shift linkage!!!
Old Sep 5, 2005 | 11:41 PM
sleeper_gsr's Avatar
Default i NeeD help taking off the shift linkage!!!
well as the topic states, i need help taking the shift linkage off. my friend iz swaping his motor out but we just cant get the linkage off. can u guys help us out please! thanxs
Old Sep 6, 2005 | 09:33 PM
qat727's Avatar
Default Re: i NeeD help taking off the shift linkage!!! (sleeper_gsr)
Really working blind here.... what kind of car, what part of shift linkage won't come off? details, details, details
If we are talking about a mt civic, then the shift rod going to the transmission is connected with a roll pin that is driven into a hole that goes through the shifter linkage and the trans shift peg. It is held surrounded by a clip, and usually covered by a rubber boot......if you don't have a civic, sry, might try posting some more info.
Old Sep 6, 2005 | 10:06 PM
fasthatchb18c1's Avatar
Default Re: i NeeD help taking off the shift linkage!!! (qat727)
aaahhh the bitch pin, how I hate it. If its that you'll need a pin puntch to get it out.
Old Sep 6, 2005 | 11:04 PM
ek-to-tha-max's Avatar
Default Re: i NeeD help taking off the shift linkage!!! (fasthatchb18c1)
that pin is truly a BITCH. its pretty tough to get it out but u can use a 12mm bolt thats long enough and hammer it out. might take a couple swings but youll get it. and im assuming its a civic. this IS honda-tech on 92-00 civics. but the way i do my swaps is alot easier so i dont have to use a cherry picker or take out the shift linkage.
Old Sep 7, 2005 | 01:09 AM
RogueWorks's Avatar
I detach it at the back, and drag it out screw that damn pin
Old Sep 7, 2005 | 02:17 AM
BoOstedEM1's Avatar
Default Re: (RogueWorks)
Yeah i usually detach at the shifter and take it out like that...then if needed ill get the pin out with extra room.
Old Sep 7, 2005 | 06:16 AM
Audi RS4's Avatar
Lover
Bitch Pin. Number 22
Matt_Jagg7
May 13, 2010 01:18 AM
hotxcivic92
Dec 3, 2007 08:55 AM
eg6sittingon57cs
Jul 19, 2007 02:41 PM
kornerk12
Mar 15, 2007 05:26 PM
JdmLsPwr425
May 26, 2004 10:25 PM
