Bogging in VTEC?
I have a SiR w/ a B16a, when I hit vtec it surges and the tach needle jumps around, I can feel it lose power but low rpm's are fine. Any ideas? I have checked the plugs, air and fuel filtes grounds and vacum lines. thanks in advance!
exhaust has nothing to do about it...
but yea fuel could b the problem either that...or ur not spark'in right...
i had the same problem...i jus changed my spark plugs and wires and cleaned my injectors and everything was fine again
The only reason I said crappy japanese exhaust is:
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delsolb16 »</TD></TR><TR><TD CLASS="quote">check your ground wires also what type of exaust system do you have</TD></TR></TABLE>
Will change plug wires and plugs and try again, thanks!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ultima »</TD></TR><TR><TD CLASS="quote">Try checking your fuel pump. It may be going out.</TD></TR></TABLE>
Ignore him, He's a homo.
lol Jk
Im just seeing if he is doing good on the forums, so far good
lol Jk
The reason i asked what type of exuast you have is because i had a dc cat back. but i kept getting pulled over so i changed it to some crappy stock type muffler and i bogged in vtec bad. Right when vtec came on it bogged all the way to 8grand.
