CEL Does not come on when I turn the Key
Old Sep 5, 2005 | 12:09 PM
MonkeyPuzzle's Avatar
Default CEL Does not come on when I turn the Key
So my car will not start and when I turn the key to the on position my CEL does not even come on.
Usually it is meant to come on for a few seconds then turn off but now it is not coming on at all.
I have tried numerous things including plugging in a different ECU, no joy.
Any ideas?
Old Sep 5, 2005 | 12:38 PM
ekb16's Avatar
Default Re: CEL Does not come on when I turn the Key (MonkeyPuzzle)
bulb burnt out maybe
Old Sep 5, 2005 | 12:41 PM
Default Re: CEL Does not come on when I turn the Key (ekb16)
possibly, I will look into that, but it seems odd that my car doesn't start at the same time I start having this problem.
Car started fine and CEL worked correctly at startup, then next day car would not start and CEL did not come on.
The only thing I did inbetween those times was tighten my axle nuts. That seems unconnected.
Old Sep 5, 2005 | 12:49 PM
JDM-EJ1's Avatar
Try checking the bulb.
Old Sep 5, 2005 | 01:39 PM
Default Re: CEL Does not come on when I turn the Key (JDM-EJ1)
Checked the bulb it works fine.
I also replaced the gauge cluster, other cluster showed the same thing.
the bulb wokrs but the CEL does not come on when I start the car.
Any other ideas?
Old Sep 5, 2005 | 01:41 PM
2k.civic.si's Avatar
jump the service connector with a paperclip and see if it stays on
Old Sep 5, 2005 | 02:30 PM
Default Re: CEL Does not come on when I turn the Key (2k.civic.si)
the CEL does not come on when the key is turned.
I have tried with the service connector jumped and without.
Any other ideas?
Old Sep 5, 2005 | 02:37 PM
b 1 6 a 2's Avatar
Your bulb is burnt. Same happened to mine.
Old Sep 5, 2005 | 02:54 PM
lsvtecracer's Avatar
Default Re: (b 1 6 a 2)
If the bulb is working and you car won't start after the problem occur then it sounds like a bad ecu. Are you sure the other ecu you tried is in good working condition??
Old Sep 5, 2005 | 03:48 PM
Default Re: (lsvtecracer)
Thanks for all your ideas but NO it is not the bulb.
Yeah the other ECU is good.
Keep em coming I want my swap to drive!!!
Old Sep 5, 2005 | 10:32 PM
Default Re: (MonkeyPuzzle)
if you jumped the service connector and the light doesnt light up then u need to start checking wiring and confirm with a volt meter that there is no voltage getting to the bulb
Old Sep 5, 2005 | 11:52 PM
Default Re: (2k.civic.si)
I just think it more than the bulb, the check engine light not coming on is NOT my problem, it is merely an indicator to my REAL PROBLEM.
THE CAR WILL NOT START.
Any ideas, I don't care about the check engine light working I want my car to work, I just thought that the CEL not coming on might be an indicator to somone of what is wrong with my car.
Anyone?
Old Sep 6, 2005 | 11:50 AM
Anyone else with this problem, it was a blown fuse.
thanks for everyones help.
Old Sep 6, 2005 | 12:38 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MonkeyPuzzle &raquo;</TD></TR><TR><TD CLASS="quote">Anyone else with this problem, it was a blown fuse.
thanks for everyones help.</TD></TR></TABLE>
now you gotta wonder why the fuse blew
Old Apr 16, 2023 | 03:04 PM
that clapped lx's Avatar
which fuse
2LGSR
Nov 18, 2010 05:16 PM
babang09
Sep 28, 2010 08:09 AM
drew10
Jul 16, 2010 04:01 PM
d_mina
Jan 26, 2004 04:56 PM
Blaze45
12
Jul 3, 2003 02:07 PM
