WILL TYPE R SHIFT LINKAGE FIT A 99 SI ...?
that makes sense.. replaced the botom only cause it bent(hit something).. if the bottom fit, then the top should i guess..
d
e
x
Modified by Project Dex at 12:37 AM 9/5/2005
d
e
x
i dont know what he ^ is talking about but
all 94-00 teg, and 99-00 SI's have the same shift linkage
basicly any B-series hydro swap besides del sol
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Project Dex »</TD></TR><TR><TD CLASS="quote">just the bottom bar.. not the one that bolts up to the body... the lengths of the shells are different..
d
e
x</TD></TR></TABLE>
dont listen to project jackass...he dont know what he's talking about ...that shift linkage is same for all b series ...just a different material i think but otherwise it will work.
d
e
x</TD></TR></TABLE>
actually on a 99-00 si has a slight different bend then the other b series shift linkages .... i did 2 swaps in the last 3 weeks ... one on a 00 si and one on a 99 ex (gsr motor) the gsr shift linkage hits the o2 sensor so the si linkage is the best to use
The place where i got my b16 shift linkage came bent, so he gave me one from a 94-up integra coupe as a replacement and it works fine. Theres no clearance issues, unless its something Im not aware of.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b 1 6 a 2 »</TD></TR><TR><TD CLASS="quote">The place where i got my b16 shift linkage came bent, so he gave me one from a 94-up integra coupe as a replacement and it works fine. Theres no clearance issues, unless its something Im not aware of.</TD></TR></TABLE>
No, you're correct. This WILL work.
ebpcivicsi1234
Mar 11, 2005 10:13 AM
