12V Source for a boost gauge?
Old Sep 4, 2005 | 02:21 PM
WildChild's Avatar
Default 12V Source for a boost gauge?
I searched but, couldn't understand. I'm installing a boost gauge into my Del Sol. And I need a switched 12V for the illumination of the guage. I know nothing about wiring.
Were would I find a switched 12V??
Old Sep 4, 2005 | 05:10 PM
turbochargeb18c's Avatar
BANNED
Default Re: 12V Source for a boost gauge? (WildChild)
you could use them 5 empty slot under the big green plug....they are 12v too...you need a test light and try each one of them to see which one comes on when you turn your headlight on....thats where i hooked up all my guage to...
Old Sep 4, 2005 | 07:50 PM
Whig-it's Avatar
don't quote me, but the 5 empty slots are: first from the left is 12V all the time, and the middle one is 12V with lights on
Old Sep 4, 2005 | 08:27 PM
gsrious's Avatar
here you go, guys and girls... make sure you thank team-integra.net
this is for obd1
this if for obd2
good luck
Old Sep 4, 2005 | 11:30 PM
WildChild's Avatar
Thanks! Exactly what I needed.
Old Nov 9, 2005 | 08:17 AM
SamC's Avatar
Default Re: (WildChild)
Can I wire more than one gauge to the same 12v source? is it safe?
Old Nov 9, 2005 | 08:20 AM
EJ1 wilcox's Avatar
Default Re: (SamC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SamC &raquo;</TD></TR><TR><TD CLASS="quote">Can I wire more than one gauge to the same 12v source? is it safe?</TD></TR></TABLE>
Yes you can. I had three gauges all running from the same source in my last car, it worked fine.
Oh also. My OBD1 car was different from those diagrams. The best way is to just use a test light and test each one individually, instead of trusting one of those diagrams.
Old Nov 9, 2005 | 08:36 AM
SamC's Avatar
Default Re: (EJ1 wilcox)
Thanks. would I need to put an inline fuse between the fuse box connector and the wires? what fuse would i use?
Also, what gauge wires would you guys recommend for autometer gauges? 18ga?
Modified by SamC at 12:05 PM 11/9/2005
JesseCivicHatch
Aug 18, 2006 04:43 AM
ViruSi
Nov 18, 2004 07:47 PM
djnikko
Nov 28, 2003 12:35 AM
civcexcoupeblack
Aug 20, 2003 01:51 PM
