Hooking up a boost gauge
Old Aug 16, 2006 | 08:02 PM
JesseCivicHatch's Avatar
Default Hooking up a boost gauge
what do i wire the boost gauge to on my 93 honda civic si... i have a garage mad turbo... it is a supra turbo with 6.8 psi of boost
Old Aug 16, 2006 | 09:38 PM
Whiteintegra's Avatar
wire the boost gage to any 12v source and a ground. Then Tap into a Vac line so you can read boost.
Old Aug 16, 2006 | 09:52 PM
AbitAvenger's Avatar
Default Re: (Whiteintegra)
i wired mine into the back of the dimmer switch to come on when i turn on my corners or lights
Old Aug 17, 2006 | 07:22 PM
UNKNOWN_MEMBER's Avatar
Default Re: (AbitAvenger)
wire that **** to the radio harness for dimmer switch.
Old Aug 17, 2006 | 11:08 PM
Schister66's Avatar
Man U FTW
if you want to do it baller style, take the power wire and push it in behind the 15amp fuse for the gauge lights so that when your gauge lights come on, the boost gauge goes on too. That's how i have my boost gauge hooked up
Old Aug 18, 2006 | 04:43 AM
Buzzbomb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AbitAvenger &raquo;</TD></TR><TR><TD CLASS="quote">i wired mine into the back of the dimmer switch to come on when i turn on my corners or lights</TD></TR></TABLE>
Same here.
CrazyModGSR
Jul 16, 2005 03:35 PM
vangc6780
Apr 26, 2005 10:10 PM
civcexcoupeblack
Aug 20, 2003 01:51 PM
