ive had it with no search, can i put Legend GS calipers on my civic?
Old Sep 4, 2005 | 07:09 AM
s1ngle's Avatar
Default ive had it with no search, can i put Legend GS calipers on my civic?
does anyone know the answer to this, or may be able to point me to a thread that addresses this? i'm crippled without the search function.
THe calipers i'm referring to are the 94-95 legend GS 2 piston calipers, and I have a 96 civic EX. Does this swap require custom adapter brackets?
Thanks!
Old Sep 4, 2005 | 08:00 AM
s1ngle's Avatar
Default Re: ive had it with no search, can i put Legend GS calipers on my civic? (s1ngle)
bumpitty, I think i've found that they will fit on my caliper brackets, but will they fit with the stock rotor size? (civic EX same as civic Si same as all integra) I think 10.4"
Old Sep 4, 2005 | 10:33 AM
DjGuamstyles's Avatar
They are wider apart (28mm) compared to Integra/Civic which are 23mm, so your caliper pistons will eventually extend all the way out. You can get some 23mm brackets and use those with the GS calipers and that will take care of the width issue, but then you'll still need to get 11" rotors for sure.
Old Sep 4, 2005 | 10:40 AM
unknown0001's Avatar
Default Re: ive had it with no search, can i put Legend GS calipers on my civic? (DjGuamstyles)
Look in my signature.
I made a thread about this brake upgrade and there is some good info posted there
Old Sep 4, 2005 | 12:27 PM
s1ngle's Avatar
Default Re: ive had it with no search, can i put Legend GS calipers on my civic? (Mr.RHTuner)
check that thread out, i made a post there that maybe you guys could help me with... basically the only thing i'm concerned about now is getting the rotor/caliper spacing right (rotor centered int he caliper...)
Override5757
Mar 6, 2012 05:10 AM
Override5757
Oct 4, 2011 11:30 AM
hondapwr
Sep 13, 2006 03:36 AM
C ronic
Jun 27, 2003 02:15 PM
crx(gator)
Sep 30, 2002 08:51 AM
