Valve cover screw snapped. Need help!
Old Sep 3, 2005 | 08:10 PM
00ekcoupe's Avatar
Default Valve cover screw snapped. Need help!
I was painting my valve cover and when I was putting everything back in, one of the two top screws snapped. Now the end with the threads is stuck in the whole and I have no idea how to get it out. Will this affect the motor or anything? How can I get this fixed?
Old Sep 3, 2005 | 10:24 PM
asubennett's Avatar
Default Re: Valve cover screw snapped. Need help! (00ekcoupe)
If any of the threads are still visible put a vise grip on them and twist it back out.
If nothing is visible to grab hold of you will have to drill it out and retap the threads.
Old Sep 3, 2005 | 10:47 PM
00ekcoupe's Avatar
Default Re: Valve cover screw snapped. Need help! (asubennett)
I can't see or grab the screw, its inside the whole. Would it be bad to drive without the screw, would anything happen? The other 4 out of 5 screws are still intact.
Old Sep 4, 2005 | 12:11 AM
.water's Avatar
there are little chance that oil will leak..but if its snapped small piece at the bottom i think it will be ok...
Old Sep 4, 2005 | 08:53 AM
veggiemaster's Avatar
Default Re: Valve cover screw snapped. Need help! (JunkyDC2)
You can use what they call an "easy out" to take the part of the broken screw out.
You have to drill a small hole in the remaining screw, thread in an easy out, and the screw should come right out.
Old Sep 4, 2005 | 09:36 AM
00ekcoupe's Avatar
Default Re: Valve cover screw snapped. Need help! (veggiemaster)
Thanks guys for the help. I'm gonna give the easy out a try today and see what happens.
Old Sep 4, 2005 | 12:15 PM
00ekcoupe's Avatar
OUT!! Wasn't hard at all. Thanks for all the help fellas.
Volkspeed
Apr 21, 2011 09:22 AM
mikej94civex
Mar 2, 2010 03:57 PM
rG`
Aug 3, 2006 02:50 PM
Hybrid 350GT
Aug 29, 2004 01:20 PM
stripes777
Jul 9, 2003 08:57 PM
