compression test on a built b18c1...tell me what you guys think....
Old Sep 3, 2005 | 08:06 PM
turbochargeb18c's Avatar
BANNED
Default compression test on a built b18c1...tell me what you guys think....
did a compression test on my built b18c1 and came up w/ 175 accross the board,but it wasn't at open throttle...so tell me what you guy think...good or bad...my set-up is:
b18c1
jg iron sleeve,81.5mm bore
9.7:1 ross pistons,eagle rods
new bearings,gasket top to bottom
p&p head w/ angle valve job(stock internals)
jg eldelbrock intake manifold( victor x)
let me know what you guys think...did it at the last min...it stated to get dark...just concern bout the compression being to low for a built b18c1....
Old Sep 3, 2005 | 08:54 PM
Combustion Contraption's Avatar
Your compression is only 9.7:1. What did you expect?
Old Sep 3, 2005 | 09:01 PM
BANNED
Default Re: (LsVtec92Hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LsVtec92Hatch &raquo;</TD></TR><TR><TD CLASS="quote">Your compression is only 9.7:1. What did you expect?</TD></TR></TABLE>
wasn't sure...i was told that it was suppoes to be up in the 200 range???.....since it was a built motor...
Old Sep 3, 2005 | 11:02 PM
turtle-eg's Avatar
Default Re: compression test on a built b18c1...tell me what you guys think.... (turbochargeb18c)
My gsr 9:1 motor with powerflow gsr head only has 150psi across the board, so you're fine.
Old Sep 4, 2005 | 12:17 AM
TurboLSVtecTeg's Avatar
Default Re: compression test on a built b18c1...tell me what you guys think.... (turtle-eg)
Ive got 225 across the board on my 9.5:1 LSVtec motor. Your numbers seem good though. My numbers where on a dry fire before initial startup. They are at 240 now.
Old Sep 4, 2005 | 08:13 AM
mmuller's Avatar
Mad Scientist
Default Re: compression test on a built b18c1...tell me what you guys think.... (TurboLSVtecTeg)
mmm, you have to test compression with the throttle open...
Old Sep 4, 2005 | 01:29 PM
BANNED
Default Re: compression test on a built b18c1...tell me what you guys think.... (mmuller)
yeah,probably do it at wot some time today....
GEN2 LS
12
Sep 29, 2009 10:43 AM
SilverPanda
Oct 9, 2007 10:25 PM
turbochargeb18c
Sep 4, 2005 01:28 PM
ddong2lee
Nov 24, 2003 09:25 AM
