Del Sol wont start, Please Help
Old Sep 3, 2005 | 02:32 PM
hatch4raceb16's Avatar
Default Del Sol wont start, Please Help
Ok. So here is the details.
-Car Cranks over fine
-I checked spark by taking plugs out and grounding them and turning the motor over. They all showed spark. Does that mean the distributor is good? Or could there still be a problem in it?
-I know there is fuel, you can hear the pump and smell gas, and the plugs were wet when I took them out.
-NO cel
Where do I go from here????
Old Sep 3, 2005 | 02:51 PM
kKdARIAN's Avatar
Vice President/CEO
Default Re: Del Sol wont start, Please Help (hatch4raceb16)
check your timing?
Old Sep 3, 2005 | 02:54 PM
philosofy1's Avatar
might be your ignition coil
Old Sep 3, 2005 | 03:01 PM
Solracer's Avatar
Probably the ignition control module
Old Sep 3, 2005 | 03:32 PM
belly-eg6's Avatar
ya dude i worked for honda for a few years its the coil
Old Sep 3, 2005 | 03:40 PM
Default Re: Del Sol wont start, Please Help (belly-eg6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by belly-eg6 &raquo;</TD></TR><TR><TD CLASS="quote">ya dude i worked for honda for a few years its the coil </TD></TR></TABLE>
where is this located? is it in the distributor?
and also, how can it be ignition related if the plugs show a spark?
Modified by hatch4raceb16 at 5:17 PM 9/3/2005
Old Sep 3, 2005 | 10:29 PM
help?
Old Sep 3, 2005 | 11:32 PM
portenio78's Avatar
I.C.M. (ignitor) is my vote also
Old Sep 3, 2005 | 11:36 PM
eldorko86's Avatar
try the main fuel relay fuse.
Old Sep 4, 2005 | 03:14 AM
Elwuudz's Avatar
I have a del sol too... I have dealt with this prob on too many occasions.
First test voltage from battery all the way through all fuses and relays.. if all seems to be good. Pull your panel off your steering colum and check the continuity on your ignition switch.
Most likely you need to replace your ignition switch if your car has any more than 100k on it.
Do not replace the entire assembly, just the switch... You can purchase a GRS ignition switch off ebay for like 50$... it will bolt up beneath your key cylinder with no modification.
If that doesnt do the trick... ever think of wiring up remote start.. or even push to start.
Relay to pass the clutch is available too.
Old Sep 4, 2005 | 03:17 AM
Elwuudz's Avatar
disregaurd last post if your car turns over...
my bad
Old Sep 4, 2005 | 03:35 AM
CrotchRocket's Avatar
Make sure that your firing order is correct as well
valve cover side:
distributor 4 3 2 1
distributor cap side:
firewall &lt; 3 4 &gt; radiator
firewall &lt; 1 2 &gt; radiator
Old Sep 4, 2005 | 03:47 AM
civic_driver's Avatar
check the fuel pressure
Old Sep 4, 2005 | 07:28 PM
Default Re: (civic_driver)
FIXED. i put my a different distributor in it, fired right up. I believe the coil inside it was bad. Can you just buy a coil from somewhere????????
Old Sep 4, 2005 | 09:38 PM
portenio78's Avatar
Default Re: (hatch4raceb16)
if thats the case I wonder if just your icm was bad(yes its inside your dizzy)
Old Sep 5, 2005 | 07:20 AM
Default Re: (portenio78)
I think it was... either the ICM or the Coil... Could I have just bought that piece from autozone or is it a honda part only. I just picked up a sohc obd1 vtec distributor from my buddy for 50 bucks. So I think thats fine.
rdh2059
Jun 9, 2024 01:26 PM
timthebiker
27
Apr 19, 2011 09:04 AM
Engage
20
Mar 29, 2009 07:49 PM
El Ban
Feb 21, 2008 04:17 AM
