1991 Std Hatch. I need wiring pin out of Guage Cluster. I need to know which is RPM
Old Sep 2, 2005 | 12:28 PM
Power Rev Racing's Avatar
Default 1991 Std Hatch. I need wiring pin out of Guage Cluster. I need to know which is RPM
I have a 1991 civic std. I have a si guage cluster in the car, it was all plug and play. It was working all the time. But the other day the whole cluster stoped working. I think i might have cut a plug or something that messed with it. My gas gauge dont work, my temp dont work, my rpm dont work. Only speedometer works becasue its mechanical not electrical.
So i need to find out the wiring of the Guage cluster, so i can wire up the RPM straight to the distributor. Can someone please give me a link or picture or tell me which wire on the cluter is the RPM. Thanks.
Old Sep 2, 2005 | 02:46 PM
exsinnovation's Avatar
Default Re: 1991 Std Hatch. I need wiring pin out of Guage Cluster. I need to know which is RPM (Power Rev
SEARCH?
Old Sep 2, 2005 | 02:52 PM
Yeah i searched. I guess i will have to look through a book at the store.
Old Sep 2, 2005 | 03:30 PM
iTe4LIFe's Avatar
hey give me about 15 to 20 mins i'll try to upload pics of what you need.....
Old Sep 2, 2005 | 03:39 PM
iTe4LIFe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">
So i need to find out the wiring of the Guage cluster, so i can wire up the RPM straight to the distributor. Can someone please give me a link or picture or tell me which wire on the cluter is the RPM. Thanks.</TD></TR></TABLE>
hey i just noticed this while i was looking through my archives for the entire guage cluster wiring diagrams..... if all you need is the tach pickup from the dizzy for the tachiee.... dude, theres tons of write ups... you could even head over to autometers site and use their instructions to find the wire. its a blue wire... I have a 88 std and i connected an aftermarket tach utilizing the blue wire on the dizzy ( there should be 2 wires... one blue and the other is black/yellow ) on my car they're to the right or the main dizzy plugs....
hey hey before i get riced... my car has the cluster WITHOUT a tach.... instead of dropping in an si cluster i bought a 2 inch tach, drilled a 2 inch hole in my dash and put it in...... looks good.... by the way, you could also use the tach pickup wire from the ecu instead of going to the dizzy.... you dont need the entire diagram anymore right? i can stop looking
:::edited:: ok im an ediot!!! i just noticed you said you need the wire pin out from the cluster and you already know which one to go from the dizzy.....
Old Sep 2, 2005 | 04:25 PM
Well i know the dizzy wire is blue, but what color is the wire directly off of the guage cluster. I am still trying to retain the stock instrument panel
Old Sep 2, 2005 | 04:38 PM
iTe4LIFe's Avatar
hey... ok that prob took more than 15 or 20 mins.... this should answer your question....
http://www.geocities.com/knigh...r.htm
hey.... even on the guage cluster its blue... according to the diagrams, its b10 or b11 (the b side should have the most pinouts)....
good luck
Old Sep 2, 2005 | 05:24 PM
vtecn8ive's Avatar
nice job man. I am planning on putting a SI cluster in my newly acquired Civic STD
Is it straight drop in?
Old Sep 2, 2005 | 08:49 PM
zCivic's Avatar
providing you get the right year its plug and play.. 88 and 89 are compatable and 90 and 91 are compatable. meaning 88 in a 90 is a PITA dont suggest it. Also it doesn't need to be an SI all Crx have tachs, HF's have a lower red line. Also can check into Sedans
To solve the problem with the post did you check your Fuses?? Check the under dash theres one for you fuses
Old Sep 5, 2005 | 12:16 PM
Well i never figured out what the problem was, and I had to go to HPDE with the car. So I did a temp fix for now. What do you guys thing
Old Sep 5, 2005 | 12:18 PM
RaysBoomBoomLude's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Power Rev Racing &raquo;</TD></TR><TR><TD CLASS="quote">Well i never figured out what the problem was, and I had to go to HPDE with the car. So I did a temp fix for now. What do you guys thing
I like it, Its all the info you need in a nice little package.
Old Sep 5, 2005 | 12:59 PM
I am thinking about putting a small guage on either side of it. Water Temp, and Oil Temp
Old Sep 8, 2005 | 10:04 AM
zCivic's Avatar
I would be worried about gas and CEL's along with temps
Old Sep 21, 2005 | 09:28 PM
dc5 kid's Avatar
check the fuse
Beau Gotti
Mar 20, 2007 02:53 PM
fast90hatch
Dec 19, 2004 07:23 AM
R6Boy69
Oct 24, 2003 09:05 AM
cornholioEK
May 3, 2003 05:31 PM
kent
10
Apr 21, 2003 06:22 PM
