Need Advice
Old Sep 2, 2005 | 12:29 AM
AkirasType-R's Avatar
Default Need Advice
I recently bought a 1997 Prelude(SH), I have some extra cash so I also picked up a Sick APEX-i turbo kit(T3/T4) I installed it myself in my dads garage(he has great tools ) I am currently running 7 p.s.i but I am not really sure how much horsepower I have. Well to cut to the chase, I want to know where I can get some quality parts so I can bullet proof the block(pistons, connecting rods, ect.) I really want to crank up the boost really high like 30 p.s.i I am currently using 550 injectors with a APEX-i F-CON. Should I use 660's for so much boost? I want to beat my cocky friends STi .
Old Sep 2, 2005 | 04:41 AM
2lude4u's Avatar
Default Re: Need Advice (AkirasType-R)
I'm not familliar with the specs or design of the Apex-i turbo kit, but I doubt it's going to run 30 psi of boost. However to beat your friends STI you won't need to run a full 30 PSI. Anyways, lookup various H-T members Turbo builds (there's a Turbo Lude thread) to familiarize yourself with parts & talk to the builder you want to work with. Remember your block needs to be sleeved. To run 15+ lbs of boost, what you'll need to clean up the STI you'll want some 720's and good engine management. If you want to run 30 lbs of boost a custom turbo Manifold with 3" exhaust piping and larger turbo are going to be needed.
Old Sep 3, 2005 | 03:37 PM
Default Re: Need Advice (2lude4u)
the T3/T4, according to the manufactuer can run up to 28 p.s.i. Will this be enough to beat the STi since it has like 350 whp?
Old Sep 3, 2005 | 04:12 PM
steveobb4's Avatar
Sleeve your block
Old Sep 3, 2005 | 04:47 PM
bby6's Avatar
I <3 Rotas
Default Re: Need Advice (steveobb4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by steveobb4 &raquo;</TD></TR><TR><TD CLASS="quote">Sleeve your block </TD></TR></TABLE>
Old Sep 3, 2005 | 11:22 PM
PrecisionH23a's Avatar
http://www.av-engineered.com
Old Sep 4, 2005 | 10:21 AM
Dougs96SI's Avatar
Default Re: Need Advice (PrecisionH23a)
You are going to need much bigger injectors than you have now.
j87w
Feb 14, 2006 09:07 PM
crxzcracer
Jun 15, 2005 04:56 PM
prabtej_si
Jan 25, 2005 09:02 PM
JonGP4
May 27, 2004 12:35 PM
