Ls/Vtec Problem Need Help right now
ls/tec with newly rebuild head having problems first there is no compression,
it does have spark, fuel, new head gasket new head studs,
it does have compression when i put oil into one of the cylinders and got 20 psi anyone have any ideas before i pull this bitch any part?
that is what we are looking at right now the head just got a full rebuilt at the shop, how do i go about knowing if the valves had been adjusted or how to adjust the valves
Yes if the valve lash is too tight you will get zero compression. Set the motor to TDC and check cylinder number one. Then rotate the mtor so that the cam gear rotate 90 degrees and check cylinder number 3 then 4, then 2.
Set the clearence to .008 intake and .008 exhasut to start. Then do a compression test and see what you got.
