How to check LMA's?
Old Sep 1, 2005 | 01:19 PM
staticrex's Avatar
Default How to check LMA's?
Any way to check if the LMA's are in good shape with out taking them out? Can I push on the top, and tell if good or bad by the rebound? I have checked valve clearences 4 times now, and yet the start up rattle is still present.
Any help is appreciated
Thanks
Mike
Old Sep 1, 2005 | 04:00 PM
PrettyLude's Avatar
i think you can check it by revving the engine up to 3k and manually giving power to the vtec solenoid
Old Nov 13, 2005 | 08:01 PM
koreanwhiteboy's Avatar
Default Re: How to check LMA's? (staticrex)
hey i have he same problem as you.. did you figure out what it is.. what part of the head is the lma.. got any pictures.. are they hard to change.. i have done the valve lash 4 to 5 times already and still make that annoying ticking noise
Old Nov 14, 2005 | 09:01 AM
gsrious's Avatar
you guys need to make sure that the ticking noise is not just your injectors or a loose exhasut mani nut, etc...
**just trying to help, however... i don't know how to check the lma
Old Nov 14, 2005 | 10:46 AM
staticrex's Avatar
Default Re: (gsrious)
nope haven't gotten around to checking them. All I know is i got alittle more rattle than I should, and the valves were adjusted less than 4k ago. Still runs strong. When I get some time, I will go over every possibility.
If you figure it out, let me knwo.
thanks
Old Nov 14, 2005 | 02:19 PM
non-VTEC's Avatar
Default Re: (staticrex)
when checking the LMA's the VTEC lifter should be lightly touching/resting on the base of the VTEC cam lobe. if there no touching the base of the cam then the LMA is collapsed or just worn out.
also when you press down on the VTEC lifter if the LMA sticks a little when you release it that is also a sign that the LMA is bad.
i just replaced all my LMA's. all 8 of them were bad. lots of ticking when cold and lots of annoying valve train noise when you rev the engine up. i did the honda prelude LMA swap and they work great for much less than half the cost of new B16/B18 LMA's.
Old Nov 14, 2005 | 03:33 PM
onepoint6i's Avatar
Default Re: (non-VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non-VTEC &raquo;</TD></TR><TR><TD CLASS="quote">when checking the LMA's the VTEC lifter should be lightly touching/resting on the base of the VTEC cam lobe. if there no touching the base of the cam then the LMA is collapsed or just worn out.
i just replaced all my LMA's. all 8 of them were bad. lots of ticking when cold and lots of annoying valve train noise when you rev the engine up. i did the honda prelude LMA swap and they work great for much less than half the cost of new B16/B18 LMA's.</TD></TR></TABLE>
w3rd
Old Nov 15, 2005 | 02:55 PM
staticrex's Avatar
Default Re: (onepoint6i)
which prelude lma's did you use? the one's for my 94 are expensive.
Old Nov 15, 2005 | 06:07 PM
non-VTEC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by staticrex &raquo;</TD></TR><TR><TD CLASS="quote">which prelude lma's did you use? the one's for my 94 are expensive.</TD></TR></TABLE>
all the info you need is in here: https://honda-tech.com/zerothread?id=566420
whiteboy-dc4
Feb 13, 2009 01:31 PM
92Eg6B18b
10
Nov 30, 2008 12:50 AM
B20BV
Dec 14, 2007 11:55 PM
skater5067
Apr 11, 2005 07:34 AM
Trungsta
Sep 29, 2004 11:00 PM
