MSD Question?
i got the blaster ss with the msd 6al box and it has all up to 8000 rpm module pill. do i need to get one that supports up to my rpm or can i just not even plug it anything in and not use it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 86si »</TD></TR><TR><TD CLASS="quote">don't put the pill in and your stock limiter will still work</TD></TR></TABLE>
I second that, if you don't have a pill in then you can only rev as far as your ecu will allow you to. But if you don't have a rev limiter (I.E. a chipped ECU) then you should have a pill in.
