msd 2 step. quick question
Old Apr 26, 2005 | 10:27 PM
BoOsTiN Dc2's Avatar
Default msd 2 step. quick question
Anyone know if i can use the msd 2 step just for the 2 step launch and leave the rev limit pill blank? Will putting a pill in module 1 and leaving module 2 empty work?
Old Apr 26, 2005 | 10:53 PM
SFWD 1934's Avatar
Default Re: msd 2 step. quick question (tRaCeBuStAbUsTeR)
What box are you referring to?
Old Apr 26, 2005 | 11:00 PM
Sinisterprostok's Avatar
Leaving the rev-limiter slot open, will allow the car to go to whatever your ecu limiter is set at. Basically it not working if you dont put in a pill. Hope this helps.
Old Apr 26, 2005 | 11:16 PM
Default Re: msd 2 step. quick question (Sinisterprostok)
im using the 6al. It wont be a problem though will it? Cuz until i buy a pill for the 2nd module i will be running the 1st module which is the 2step launch. My question is just will i have a problem with it. Im pretty sure i won't have a problem but i just wanna make sure, stock rev limit will be fine for the time being since i can adjust it cuz i have hondata and i intend to get the pill soon but not until i get tuned. Thanks for the fast response btw
Old Apr 27, 2005 | 12:14 AM
importdude2000's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tRaCeBuStAbUsTeR &raquo;</TD></TR><TR><TD CLASS="quote">im using the 6al. It wont be a problem though will it? Cuz until i buy a pill for the 2nd module i will be running the 1st module which is the 2step launch. My question is just will i have a problem with it. Im pretty sure i won't have a problem but i just wanna make sure, stock rev limit will be fine for the time being since i can adjust it cuz i have hondata and i intend to get the pill soon but not until i get tuned. Thanks for the fast response btw</TD></TR></TABLE>
its fine
the ecu will cut it
the 6al does not bypass the ecu and cut it off
msd only cuts off ignition
have fun 2steping
leaving a slot open will just not limit anything
tigueremalo
Oct 20, 2006 09:55 AM
Mr HYDE
Sep 1, 2005 09:26 PM
allmotorhatch
Feb 12, 2005 09:23 AM
sirminder
Oct 1, 2003 04:32 AM
