msd pills?
Old Jun 16, 2003 | 10:24 AM
b16 matt's Avatar
Default msd pills?
I dont have any of the rpm pills for my msd. Will it still work without them?
Old Jun 16, 2003 | 10:27 AM
b16 matt's Avatar
Default Re: msd pills? (b16matt)
bump 4 me
Old Jun 16, 2003 | 10:44 AM
b18bturbo's Avatar
MSD rpm swithc or what is it .. It will not work without though. If it jsut shift light or something like that then that acceosory will be affected
Old Jun 16, 2003 | 10:50 AM
b16 matt's Avatar
Default Re: msd pills? (b18bturbo)
ya the little rpm module that actually goes on the msd unit. there is one for 7k and 8k and etc.
Old Jun 16, 2003 | 12:07 PM
b16 matt's Avatar
just a rev limiter it will still work without them I found out.
Old Jun 16, 2003 | 12:49 PM
ion_four's Avatar
The pills are just resistors in a fancy package. Nothing more. I think 8000rpm is around 3k ohm (but I could be totally wrong as that's just what I recall).
Just try to hook something up and see what happens. More resistance should be lower rev limit.
Old Jun 16, 2003 | 02:01 PM
JT's Avatar
JT
Default Re: msd pills? (ion_four)
I didn't like the limited range of those rpm pills, so I custom made my own. It can be set to any rpm up to around 10K.
Old Jun 16, 2003 | 02:24 PM
boosted92's Avatar
Default Re: msd pills? (JT)
What RPM's do you need? I think I might have a couple laying around from my nitrous days.
Old Jun 16, 2003 | 04:59 PM
ion_four's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JT &raquo;</TD></TR><TR><TD CLASS="quote">I didn't like the limited range of those rpm pills, so I custom made my own. It can be set to any rpm up to around 10K.
Very good man! I did something similar to that. I just found a little connector that I hacked up that would plug into there and ran a couple wires to a POT on the cabin. I was also going to hook it up in series with another resistor through the clutch switch (to lower the rev limit when it's in) for full-throttle shifting and launch control...BUT, I just took out my 6btm. SO, if someone is in the market for one, hit me up! It's in perfect working order, but scuffed up
Old Jun 16, 2003 | 05:31 PM
b16 matt's Avatar
Sweet Im awn it! What is the value on that potentiometer?
Modified by b16matt at 2:44 AM 6/17/2003
boostedcivicsir
May 2, 2010 10:44 AM
torr
Aug 4, 2004 08:08 AM
M.A.R.C.
Jun 20, 2004 02:56 PM
Rhetoric
Dec 16, 2001 12:05 PM
