Turning over slowly = dead battery?
Old Aug 31, 2005 | 01:47 PM
MooreBoost's Avatar
Default Turning over slowly = dead battery?
I tried to start my recently built motor this afternoon and finally got it to turn over, however it was very slow and wouldn't start. I have a mini battery in the car that was not used for a year, so I had it hooked up to the battery of a running car with jumper cables. Do I need to replace or recharge the battery?
Old Aug 31, 2005 | 07:26 PM
MooreBoost's Avatar
Default Re: Turning over slowly = dead battery? (MooreBoost)
Anyone?
Old Aug 31, 2005 | 08:10 PM
slomofo's Avatar
GDD Member
Jump start the car, drive it around for a while to get the electrolyte in there moving around, go home park it, jump start it in the morning, do the same routine. It'll start holding a charge after about 4 jump starts, if not, then the battery is bad. OR you can just charge the battery for a full day, then throw it in and it should be fine.
Old Aug 31, 2005 | 08:23 PM
new2novas's Avatar
Default Re: (slomofo)
batt is probably dead, don't even bother with it unless it was $$$$, otherwise cop a new one and foget the headache, then you can single that out as even being an issue
Old Aug 31, 2005 | 08:53 PM
fwdtamiya's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by slomofo &raquo;</TD></TR><TR><TD CLASS="quote">Jump start the car, drive it around for a while to get the electrolyte in there moving around, go home park it, jump start it in the morning, do the same routine.</TD></TR></TABLE>
Gatorade?
TNight
12
Apr 21, 2014 04:39 PM
Hatchman98
Apr 24, 2007 06:54 AM
cvaladez2
26
Mar 10, 2007 09:41 AM
yellowmonkeyboy
Nov 26, 2003 11:38 PM
vizsual00
Aug 11, 2003 11:48 AM
