ECU
Old Aug 31, 2005 | 04:58 AM
q45mm's Avatar
Default ECU
Alright searched and searched again but couldn't find the answer im looking for.
I have 99 ex 1.6 V-tech im going to run hondata on my car but i want to run an OBD I ecu I need to know all the my options for SOHC ecu's or just good ecu's to run and this is for a turbo set up non- daily driver running approx. 18 psi. track only. I will also need to know where i can get a good step down harneness. or should i ditch the hondata and go with another stand alone magement system.
feel free to say anything coments, concerns, or just critisize my set up
Old Aug 31, 2005 | 05:38 AM
q45mm's Avatar
Default Re: ECU (q45mm)
Anyone
Old Aug 31, 2005 | 06:44 AM
siregcivic's Avatar
get a p28 obd1 ex/si ecu... and have it chipped with crome or uberdata
Old Aug 31, 2005 | 07:23 AM
cibola's Avatar
Do the AEM better interface than the Hondata. If you do the OBD1 ECU and S200 with all the unlocks for a good turbo setup it will cost as much as the AEM.
Old Aug 31, 2005 | 07:45 AM
Relic1's Avatar
Default Re: (siregcivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by siregcivic &raquo;</TD></TR><TR><TD CLASS="quote">get a p28 obd1 ex/si ecu... and have it chipped with crome or uberdata</TD></TR></TABLE>
Old Aug 31, 2005 | 07:49 AM
q45mm's Avatar
what makes uberdata better then hondata
Old Aug 31, 2005 | 07:50 AM
q45mm's Avatar
what are the significant diffrences
Old Aug 31, 2005 | 07:53 AM
hoffman4684's Avatar
Uberdata is relativly free if I remember right. I know that Crome is.
Old Aug 31, 2005 | 08:00 AM
Deemeetree's Avatar
Electrician
You're going to be running 18 PSI on a, what looks like and sounds like, a stock D16Z6?
Old Aug 31, 2005 | 08:04 AM
Luserkid's Avatar
Default Re: (Deemeetree)
Crome and Uberdata are built around hondata, they are the same minus being free and expensive.
Let the kid learn on his own.
Old Aug 31, 2005 | 08:39 AM
q45mm's Avatar
no not stock
bored over, gaurd , reselved egale rods, wes pitons
havent really looked into the top end half yet but plan on befor i even put it togethor this is basicly a rough sketch but if u have any recomandations let me here um
Old Aug 31, 2005 | 08:47 AM
q45mm's Avatar
if anyone has an info site or a forum on here or something let me know im currently searching so it would be much appreciated
Old Aug 31, 2005 | 09:12 AM
q45mm's Avatar
does anyone know where i can get info on uberdata chrome etc
Old Aug 31, 2005 | 09:24 AM
Relic1's Avatar
http://www.pgmfi.org/ - and start reading.
there is a forum on there too with even more info.
white2draccord
Apr 27, 2008 09:21 PM
blwn95civic
Jan 10, 2007 06:11 PM
zeroz
Apr 13, 2005 12:02 PM
rocketfuelcerx
Jan 31, 2005 08:19 PM
tub_sephiroth
Nov 18, 2004 10:27 PM
