Suspension & Brakes Theory, alignment, spring rates....
cutting bushings bad?
Old Aug 31, 2005 | 01:46 AM
0utaSight's Avatar
Default cutting bushings bad?
my suspension is koni yellows from an EK, my car is a EG hatch, and i have to cut the bushings on the rear LCA, inorder for the shocks to fit. my question is, is it dangerous or would it effect performance? thanks
Old Aug 31, 2005 | 08:28 AM
Gillard82's Avatar
Default Re: cutting bushings bad? (0utaSight)
i dunno if i would do it, id be nervous as hell
Old Aug 31, 2005 | 09:06 AM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: cutting bushings bad? (Gillard82)
It can be done, but I would rather "grinde" than "cut". The trick is gonna be to keep the bushing sleeve flat. Don't grind at an angle.
Why so many people get parts that arn't for their car, I'll never know...
Old Aug 31, 2005 | 11:08 AM
0utaSight's Avatar
Default Re: cutting bushings bad? (94eg!)
so what can u use to "grinde" it?
Old Aug 31, 2005 | 11:23 AM
94eg!'s Avatar
#1 Super Guy
Loved
A grinder, duh...
Remove the LCA, and grind on the ears of the bushing with a bench grinder. Make sure to mark the metal, so you know when to stop removing material (to much is bad). Also, make sure that you remove equal amounts of material from both sides of the bushing. All the cars wheight rests on that bushing, so it must be focused in the center...
Example:
Old Aug 31, 2005 | 01:48 PM
Relic1's Avatar
^^^^ and watch the temp of the bushing. rubber bushings do not like a lot of heat. (for obvious reasons)
Old Aug 31, 2005 | 07:24 PM
Domani_Vi-RS's Avatar
sounds like a bod idea to me right off the get go...but grinding it would be your best bet. hell, why not paint it as well? lol!
Old Aug 31, 2005 | 11:20 PM
94eg!'s Avatar
#1 Super Guy
Loved
Default Re: (Domani_Vi-RS)
It is totaly doable (people seem to do it all the time on H-T), but I wouldn't risk it. Just sell your rear shocks & buy new ones for your model...
willimo
Suspension & Brakes
Sep 28, 2012 08:54 AM
s13hero
May 5, 2012 07:11 PM
Etorres325
Suspension & Brakes
Apr 28, 2010 02:03 PM
RalliartRsX
Suspension & Brakes
Oct 4, 2005 07:44 AM
D.Lansing
Sep 15, 2002 09:58 AM
