sir2 TB gasket
Old Aug 29, 2005 | 07:40 AM
komat's Avatar
Default sir2 TB gasket
does anyone know which car tb gasket i should be using for a b16a sir2 throttle body
i tried a 99-00 si gasket but it didnt fit unless adv auto send me the wrong one
need a gasket that will fit this
Modified by komat at 2:54 AM 1/12/2006
Old Aug 29, 2005 | 10:42 AM
komat's Avatar
Default Re: sir2 TB gasket (komat)
bump i need a new gasket!
Old Aug 29, 2005 | 11:39 AM
nighttrain33's Avatar
When I put my skunk2 im on, I was having a problem with a leak in that area. I used a y8 gasket and it fixed my problem. Not sure of your mods, so tough to say if the same is true for you.
-Shane
Old Aug 29, 2005 | 01:15 PM
komat's Avatar
Default Re: sir2 TB gasket (nighttrain33)
i have stock everything jdm b16a sir2
when i took my Tb off the manifold the gasket got ripped
Old Aug 29, 2005 | 04:48 PM
komat's Avatar
bump what gasket do i use
Old Aug 29, 2005 | 06:54 PM
urnotfast's Avatar
up for komat............................huuuudddddaaaaaaw aaaahhhhhhhh!!!!!!!!!!!!!!!!!!!
Old Sep 1, 2005 | 10:37 AM
komat's Avatar
Default Re: sir2 TB gasket (urnotfast)
lkasjdflk;asdjflk;jasd;lf
Old Sep 28, 2005 | 08:58 AM
komat's Avatar
i need a gasket
who knows what car gasket willfit!
Old Sep 28, 2005 | 10:37 AM
JibOnALib's Avatar
I'm not exactly sure on this, but maybe a b16a3 gasket would be simialar?
Old Sep 28, 2005 | 11:04 AM
CRXified's Avatar
try a del sol vtec, like a 1994, i think htose will work.. but the 99-00 SI (Sir form me, yay canada) should have worked..
Old Sep 28, 2005 | 04:06 PM
postman's Avatar
Default Re: sir2 TB gasket (JibOnALib)
try the b16a3, 94 delsol vtec/ i have a 94 sol with 2nd gen b16a, and use alot of parts from the a3 to intermix
Old Jan 11, 2006 | 09:08 PM
komat's Avatar
Default Re: sir2 TB gasket (postman)
just tried one from a del sol didnt work
does anyone know where i could get a gasket for my TB for my 2nd gen b16a(sir2)
Old Jan 11, 2006 | 10:22 PM
PinkMaggit's Avatar
rubber make a gasket stuff? would that work?
Old Jan 11, 2006 | 10:51 PM
komat's Avatar
Default Re: sir2 TB gasket (PinkMaggit)
my tb looks like this
i keep getting gasket that looks like this
Old Jan 11, 2006 | 10:55 PM
Sleepy_Red_hatch's Avatar
****, i always thaught a sol Vtec had almost all interchangeable parts with the SiR 2
Here's the piece for the SiR 1
Throttle Body Gasket 16176-PR3-010 90-91 integra
so im thinking maybe an obd1 LS Tb gasket would work?
worse to worse, im sure you can find gasket bulk material and make you're own...
Old Jan 11, 2006 | 11:07 PM
komat's Avatar
Default Re: sir2 TB gasket (Sleepy_Red_hatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sleepy_Red_hatch &raquo;</TD></TR><TR><TD CLASS="quote">****, i always thaught a sol Vtec had almost all interchangeable parts with the SiR 2
worse to worse, im sure you can find gasket bulk material and make you're own...</TD></TR></TABLE>
the 90ls is the same as the pic i showed unless adv auto has it wrong
Old Jan 11, 2006 | 11:16 PM
Calvinator's Avatar
I think it looks like you need an automatic gasket. I would try an automatic 94-01 LS gasket. They seem to be longer than the other ones.
Old Jan 11, 2006 | 11:52 PM
dantastic's Avatar
http://www.hondaautomotivepart...81%29
that's what the '95 del sol vtec TB gasket looks like. it's cheap, just go to a dealer to buy it.
Street_sleeper
Engine Management and Tuning
Jul 28, 2011 05:19 AM
journeyquest
Sep 3, 2010 12:39 AM
sup22
Aug 19, 2007 11:17 AM
civic_driver
Sep 25, 2005 11:51 PM
(__________)
Jun 17, 2003 03:25 PM
