idles very low
Old Aug 28, 2005 | 03:27 PM
acmeotally's Avatar
Default idles very low
i have a 92 si with a stock motor and after about 5 min of it running the engine will actually idle at 100 rpm then try to stall and go up to around 500. i searched for it and i did some of the sugg and didn't work. i got a new main relay and i re did the engine ground. im thinking its a iacv or a leak in the im any help would be appreciated
Old Aug 28, 2005 | 03:40 PM
mericbe's Avatar
Default Re: idles very low (acmeotally)
Check your map sensor I'm having sorta the same problem
Old Aug 28, 2005 | 04:07 PM
acmeotally's Avatar
Default Re: idles very low (mericbe)
thanks ill try it
Old Aug 28, 2005 | 05:03 PM
BDogggUT34's Avatar
on my b18b, i was having the same problem along with a little roughness in the idle also. I took off the IACV and cleaned it with throttle body cleaner and then took the intake off and used the rest of the bottle into the IM. I then seafoamed the motor. After doing this it raised my idle and smoothed it out, i then actually had to adjust the idle down using the idle screw. This at least worked for me!
Old Aug 28, 2005 | 05:13 PM
Falqon's Avatar
How are you reading 100RPMs? I don't think your stock tach shows that.
Old Aug 28, 2005 | 05:32 PM
acmeotally's Avatar
Default Re: idles very low (Falqon)
it shows it almost at the line it would be at if it was shut off so i don't really know also im not throwing any cels
Old Aug 28, 2005 | 05:34 PM
shinlegion's Avatar
I would just raise te idle on it little, if the car is running fine otherwise.
Old Aug 28, 2005 | 09:10 PM
Falqon's Avatar
Default Re: idles very low (shinlegion)
I think the lowest line on your tach is 500 rpm. Sounds to me like you've got a vacuum leak and a hunting ECU and idle is coming down to around normal you're just not used to it.
Old Aug 28, 2005 | 10:24 PM
z6's Avatar
z6
with these gas prices you should be happy your motor idles at 100rpm
yay for vtec
98silver-civic
Sep 28, 2009 05:46 AM
mikeunreal2
Mar 29, 2006 09:27 PM
90AcuraIntegra04
Dec 11, 2005 05:26 PM
Tw1n Turb0 Z
Oct 18, 2003 07:23 PM
TurboCRVTEC
Oct 9, 2002 05:38 AM
