vtec not pulling
i have a 2nd gen b16 and when vtec engages at 5500rpm it doesnt pull like it use to.. Performance feels the same as it would feel before vtec.. All my grounds are fine. Sometimes my car throws cel 17 vss speed sensor after 10 minutes of driving, but my speedo works fine and vtec still engages while the check engine is on, its just that it feels like im not making any power in vtec, maybe its time for an oil change??
mods:
chipped p28
itr cams
DC header
NGK wires and Plugs
B&M fuel regulator
2.25 piping w/no cat converter
mods:
chipped p28
itr cams
DC header
NGK wires and Plugs
B&M fuel regulator
In addition to doing an oil change, check the filter screen behind the VTEC solenoid. Sometimes it gets clogged and dirty, not allowing sufficient oil pressure to the head.
Because the ECU use a speed signal for fuel mapping, I would think that your speed sensor is the problem, why it doesn't feel strong. Check the plug. I have seen the plug corrod and cause a cel. Look for greenish blue stuff on the plug like a battery terminal gets when it is corroding.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanwill »</TD></TR><TR><TD CLASS="quote">Because the ECU use a speed signal for fuel mapping, I would think that your speed sensor is the problem, why it doesn't feel strong. Check the plug. I have seen the plug corrod and cause a cel. Look for greenish blue stuff on the plug like a battery terminal gets when it is corroding.</TD></TR></TABLE>
where can u buy the filter from if it needs to be changed?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blk007 »</TD></TR><TR><TD CLASS="quote">
where can u buy the filter from if it needs to be changed?</TD></TR></TABLE>
another place you can get it is from inline four http://www.inlinefour.com/bservtecsolg.html
b16mike
May 13, 2005 09:51 PM
civicHBphtride
18
Jul 16, 2004 10:49 PM
South Bay Surfer
23
Jan 2, 2003 04:42 AM
