Problem: Weird vtec sputter at changeover
my car didnt do this until my engine bay got soaked when my radiator hose flew off while on the highway and i had to pull into car wash to get hose rinse engine bay areaa..... and then refull the radiator and attach the hose....
the next day car runs perfect other than vtec commit/engage at full throttle... i can ease it into vtec and it will run but as soon as i floor it vtec sputters bad sounds like its cutting in and out...
i check all my grounds and they are all good... changed out wires... what do u think is next
Could have nothing to do with the spill..
My car did the same......... well to think I was a little different. I could Floor it into VTEC and it would switch over smoothly, but when I ease it into it sputters, Turned out I had a Intake Manifold Gasket Leak. ..
So my Advice would be to check for any vaccum leaks anywhere.
Also who does it idle now???
some one has to have had this problem before its weird and sounds dumb but its happening and wasnt happening 2 days ago and i didnt change anything
OK heres the deal now the situation changed a bit when i turn the car on i can hit vtec no problem for like 3 times.... ok then car will start doin sputtering again...
but when im driving if it starts sputtering if i turn the car off and then back on i can hit vtec again for a little bit and then it starts to sputter again what does it sound like to you guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">Check your oil level.</TD></TR></TABLE>that to
Ok this happens I used to work at a carwash and we had this happen to 70% of the cars. they all had a different problem tho. Some would misfire, some would throw cels, and others just wouldn't just start at all. Then a few days later it would be just fine. It's just water soaking up wires and the such... Underhood heat boils it away.
I'm not sure why having enough oil affects VTEC, on my Civic, it doesn't matter, but a friend of mine's Accord does exactly what you're talking about unless he fills it a little above the mark.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by O16581724 5 2 5 »</TD></TR><TR><TD CLASS="quote">I'm not sure why having enough oil affects VTEC, on my Civic, it doesn't matter, but a friend of mine's Accord does exactly what you're talking about unless he fills it a little above the mark.</TD></TR></TABLE>
im going to try that!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std »</TD></TR><TR><TD CLASS="quote">Ok this happens I used to work at a carwash and we had this happen to 70% of the cars. they all had a different problem tho. Some would misfire, some would throw cels, and others just wouldn't just start at all. Then a few days later it would be just fine. It's just water soaking up wires and the such... Underhood heat boils it away.
Its been alot of days and still its doing it
</TD></TR></TABLE>Its been alot of days and still its doing it
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Morhpeous »</TD></TR><TR><TD CLASS="quote">im getting spark my car starts and runs good cept until vtec... dont know how good of a spark im getting though could that be the problem</TD></TR></TABLE>
yes sir, that happened to me for almost 2 months then my distributor just took a ****.
is your motor stock?
NATURAL ASPIRATI0N
Jun 14, 2004 08:52 AM
