Unknown usage for ground under/behind cluster
Old Aug 27, 2005 | 12:51 PM
aenima_20's Avatar
Default Unknown usage for ground under/behind cluster
can anyone tell me what this ground is used for ? I cant figure it out
Old Aug 27, 2005 | 12:54 PM
Kyles ej1's Avatar
Default Re: Unknown usage for ground under/behind cluster (aenima_20)
wheres the wire lead to?
Old Aug 27, 2005 | 12:55 PM
aenima_20's Avatar
Default Re: Unknown usage for ground under/behind cluster (93ejay1)
if it would lead somewhere do you think I would be asking ??
Its just going nowheres
Old Aug 27, 2005 | 12:59 PM
Kyles ej1's Avatar
so its cut and just hangs there?
Old Aug 27, 2005 | 01:00 PM
96civich22's Avatar
i wouldnt worry about it...all grounds are put there for a reason....if you remove it just put it back
Old Aug 27, 2005 | 01:03 PM
aenima_20's Avatar
Default Re: Unknown usage for ground under/behind cluster (96civich22)
the ground doesnt go anywhere!
the other end that is not connected to the chassis doesnt go to anything like the stereo or something
thats what im trying to find out
where does the other end of this ground should plug in
Old Aug 27, 2005 | 01:04 PM
aenima_20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 93ejay1 &raquo;</TD></TR><TR><TD CLASS="quote">so its cut and just hangs there?</TD></TR></TABLE>
yeah, I wanna plug everything back properly
Old Aug 27, 2005 | 01:12 PM
American.Graffiti's Avatar
I just recently had a problem when I left mine unplugged and it didnt allow my tail lights to be on. A better description would be that my tail lights worked but they wouldnt be on when I turned my lights on, only when I applied the brakes. I dunno what anyone else went through if/when they left theirs unplugged but thats my experience.
Old Aug 27, 2005 | 01:17 PM
aenima_20's Avatar
Default Re: Unknown usage for ground under/behind cluster (Falkien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Falkien &raquo;</TD></TR><TR><TD CLASS="quote">I just recently had a problem when I left mine unplugged and it didnt allow my tail lights to be on. A better description would be that my tail lights worked but they wouldnt be on when I turned my lights on, only when I applied the brakes. I dunno what anyone else went through if/when they left theirs unplugged but thats my experience. </TD></TR></TABLE>
thanks man
at least I now know for sure it has to do with the lights
Old Aug 27, 2005 | 01:47 PM
aenima_20's Avatar
is it possible this would be the ground for the stereo ?
the wire has 2 silver spots every inch or so
Old Aug 27, 2005 | 07:56 PM
There is a possibility b/c the radio has a ground wire that might run to that.
Old Sep 2, 2005 | 05:59 PM
00000xxx's Avatar
Default Re: (Falkien)
its for the head unit
Old Sep 3, 2005 | 01:54 AM
BlueIntegraBoy's Avatar
Default Re: (ctr610)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ctr610 &raquo;</TD></TR><TR><TD CLASS="quote">its for the head unit</TD></TR></TABLE>
Correct!!! I forgot to put this back when I did my black interior conversion (dash swap) and my radio didn't work. Plugged it in and it worked.
Old Sep 3, 2005 | 07:05 AM
Hello Bart's Avatar
you dont think thats the ground for your gauge cluster?
Old Sep 3, 2005 | 07:15 AM
litterbox's Avatar
I am a (Trial User) Army
Default Re: Unknown usage for ground under/behind cluster (Hello Bart)
This ground is for the gauge cluster. It is linked up on the underdash harness.
The headunit grounds down by the lower center part of the dash.
At least it's like that on Teg's.
Old Sep 3, 2005 | 12:04 PM
Default Re: Unknown usage for ground under/behind cluster (litterbox)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by litterbox &raquo;</TD></TR><TR><TD CLASS="quote">This ground is for the gauge cluster. It is linked up on the underdash harness.
At least it's like that on Teg's.</TD></TR></TABLE>
It was a ground for my headunit.
Old Sep 3, 2005 | 01:22 PM
adictionbass's Avatar
Default Re: Unknown usage for ground under/behind cluster (BlueIntegraBoy)
yea, when i left mine disconnected, none of the gauge lighting worked..
Old Sep 4, 2005 | 11:35 PM
Hello Bart's Avatar
Default Re: Unknown usage for ground under/behind cluster (adictionbass)
same thing happened to mine, I would just make sure you hook it up
AmbiguousCivic
Jun 25, 2007 09:28 PM
turbostd
Apr 10, 2007 04:35 PM
shivic
Dec 21, 2006 08:07 AM
O16581724 5 2 5
Sep 18, 2005 02:05 PM
crxman00
Sep 21, 2003 09:08 PM
