how hard is a block swap on a d16?
Old Aug 27, 2005 | 12:14 PM
Kyles ej1's Avatar
Default how hard is a block swap on a d16?
my engine is kncocking so i found a longblock for cheap and want to just put on the bottome end. how hard is it to just swap the blocks? i searched and found NOTHING
Old Aug 27, 2005 | 12:38 PM
Neighborhood Superstar's Avatar
Default Re: how hard is a block swap on a d16? (93ejay1)
you sure the knocking isnt from the head?
Old Aug 27, 2005 | 12:44 PM
Kyles ej1's Avatar
Default Re: how hard is a block swap on a d16? (=Gameover=)
i was told the head cant knock.....can you explain how it would?
im pretty sure its rod knock cuz there was leak and there was NO OIL when i checked it
Old Aug 27, 2005 | 12:47 PM
Dueceification's Avatar
It's that hard just time consuming. Your gonna have to remove the motor & tranny put everything on to the new block and reinstall the motor.
Kyles ej1's Avatar
Default Re: how hard is a block swap on a d16? (93b16hatch)
so you do have to remove the motor?
Old Aug 27, 2005 | 01:02 PM
A.E Motoring's Avatar
yup...
1. undo all connectors
2.all hoses
3.fuel lines
4.electrical
5.yank motor out
6.dissasemble the motor
7.reasemble everything onto new block
8.put motor back in and connect everything
oh yea...make sure everything is down to torque specs
Old Aug 27, 2005 | 01:06 PM
Kyles ej1's Avatar
Default Re: how hard is a block swap on a d16? (SPNFEDEJ)
**** that then ill just buy another motor then
Old Aug 27, 2005 | 08:19 PM
m00nr0ck Si's Avatar
good choice! http://www.hmotorsonline.com
Old Aug 27, 2005 | 08:21 PM
hatchi's Avatar
if you want to pay to have motor swapped out hit me up
Old Aug 27, 2005 | 11:19 PM
Kyles ej1's Avatar
Default Re: how hard is a block swap on a d16? (dorkoftheyear)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dorkoftheyear &raquo;</TD></TR><TR><TD CLASS="quote">good choice! http://www.hmotorsonline.com </TD></TR></TABLE>
werd gonna give them a call on monday.....i was gonna call em today but theyre closed on weekends
Acidcrakker
Oct 8, 2007 04:05 PM
slammedcoupe
Sep 25, 2005 10:10 PM
J.D.M.
Mar 17, 2005 01:43 PM
philly-O
Sep 14, 2002 06:47 AM
