Did 1" MC and BB swap but pedal feels mushy
Well I put an Integra 1" Master Cylinder and Brake Booster along with a 40/40 Prop valve on my car but still have the stock drums on it (just trying to put things back together to drive the car to a shop with a lift to do the ebrake cables and trailing arms). I bled all four sides but when I test drove the car the pedal goes 3/4 the way down before it grabs then theres pressure if you pump them. I dont have much brake experience so Im just looking for some input from someone who recognizes the issue.
Thanks
btw. 96 civic ex is the car
Thanks
might still have air in the system. I could understand if it took 1/4 or 1/2 way before the brake bite but 3/4 way is too much. BTW how did you bleed the brake and which side did you start with? It's weird with Hondas, some of the model years are different, even among the integras(94-95, 96-98, 00-01) and civics(92-95, etc...) themselves.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SAVIOVEGA »</TD></TR><TR><TD CLASS="quote">Bleed Pass Rear, Driver Front, Driver Rear, Pass Front
also keep pedal pumping at a minimum. The more you pump the pedal the more those big air bubbles turn into little ones
apexi_rsx
14
Dec 30, 2012 04:55 AM
EGh22please
Apr 30, 2011 12:34 PM
