oil return line 5/8 ID
Old Aug 26, 2005 | 10:31 AM
bayoufrogg's Avatar
Default oil return line 5/8 ID
I got the hose fitting on my turbo and was told to use high pressure/high temp. fuel line and connect in to the welded pipe in my pan. Ive called NAPA, CARQUEST, Advanced AUto, and even a few hydrolic hose places. No-one has 5/8 ID high temp fuel or diesel line. Any ideas. Everything else is done with the turbo setup.......just need the piece of hose. thanks
Old Aug 26, 2005 | 11:13 AM
beepy's Avatar
Default Re: oil return line 5/8 ID (bayoufrogg)
Use any hose that is rated for oil. The oil drain is not high pressure. Hell, it should be zero pressure.
Old Aug 26, 2005 | 11:15 AM
wantboost's Avatar
Who is Mr Robot?
Default Re: oil return line 5/8 ID (beepy)
or just buy some braided line, it will hold up better over time
Old Aug 26, 2005 | 11:31 AM
Maveric's Avatar
Default Re: oil return line 5/8 ID (wantboost)
yep any Oil hose will do...
Old Aug 26, 2005 | 11:49 AM
N20civicB18's Avatar
Default Re: oil return line 5/8 ID (Maveric)
I think i used heater hose before I used SS... if the line is reinforced (you can see strains of like string when you cut it) then it is rated for what you need.
Old Aug 26, 2005 | 01:04 PM
bayoufrogg's Avatar
found some from another forum - only problem now is that the temp range only goes up to 212 F . since the line has to be run between my block and downpipe, thats gonna be too hot. any ideas on what kind of material to wrap with and protect from heat
turboman
Apr 24, 2006 07:57 PM
Black R
Feb 20, 2005 03:12 PM
C1V1CS1
Oct 16, 2002 12:23 PM
pelotudo
Aug 24, 2002 12:20 AM
Jockobo
Jun 15, 2002 07:41 PM
