ball joint on cx hatch
sup guys i got a 92 cx hatch.. My lower ball joint on the driver side hub is just spinning ive tried everything. ive managed to get a bolt on there like 2 turns but when i drive its really unsafe and you can deff feel it. How hard is it to swap out the ball joint. Ive already got a new one. How much will a normal shop charge or can i do myself.. thanks guys
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by underb00steg6 »</TD></TR><TR><TD CLASS="quote">you can do it yourself ...its not hard , you just figure it out and work at it. air tools always makes it easier!
That response makes no sense at all. Why would air tools help that??
Have a friend stand on top of the brake/rotor/knuckle assembly then tighten the bolt. Should work fine.
</TD></TR></TABLE>That response makes no sense at all. Why would air tools help that??
From: With my POS D15B2, Whereever whenever, United States
replace the ball joint.
Having someone step on the hub is just prolonging the bullshit you'll have to deal with later when you want to take the axles out for whatever reason.
Change the ball joint, 25 bucks at autozone
hammer it out and hammer it back in
got 1 for 30 bucks at pepboys. i already had someone step on it to make pressure so i could get a bolt on . threads r stripped and stud is still spinning. I need to replace. is it really that easy Just hammer it in and out?
the reason why you can't hammer it in is because you need a 25-33mm, don't know the size, to go on top of the ball joint so while you are hammering it in, it goes in evenly.
A press is hard to fit because the damn hub has so limited room.
I'd take a picture, but its in the car and I am not taking it off
Exactly what they said, hammer works best. To press it back in i used a bench vice and hammered it in. Worked like a charm. Autozone also lets you borrow the tool for the job. I only found it useful to press the new one in but not to press out
COLLIER67
23
Jun 19, 2007 08:45 PM
