obd0 motor in a ej1?
Old Aug 25, 2005 | 10:46 PM
donut.'s Avatar
Default obd0 motor in a ej1?
i just bought a obd0 b16 for a great price. now my plans were to sell the tranny and get a hydro one. but my main concern is that the motor itself is off a ef, therefore being obd0. how do i make this work with my obd1 harness?
Old Aug 25, 2005 | 10:51 PM
SirRevvs's Avatar
Default Re: obd0 motor in a ej1? (Hugh G. Rection)
Use your existing OBD1 harness on that engine. Should work just fine, you may need to alter a few wires (lengthen and such). Use your injectors as well. I think you might have to get a OBD1 or OBD2 alterntor though.
I have a question: you've been a member for 4 months and you have 3300+ posts. Sir, are you a *****?
Old Aug 25, 2005 | 10:57 PM
donut.'s Avatar
Default Re: obd0 motor in a ej1? (SirRevvs)
ok i just found out i need to get OBD1 injectors and alternator. is that all i need to do to the head? it has a skunk2 IM too. and do i need to change anything on the block? or alternator?
Modified by Hugh G. Rection at 12:07 PM 8/26/2005
Old Aug 25, 2005 | 11:02 PM
SirRevvs's Avatar
Yeah just an alternator and injectors should be all you need, besides the hydro tranny, rear motor mount, and top tranny and driver side mount.
Old Aug 25, 2005 | 11:07 PM
donut.'s Avatar
ok, so i need a obd1 distributor, alternator, and injectors. thats it? can someone second this?
Old Aug 26, 2005 | 02:25 AM
sicky's Avatar
grammer nawzi
Make sure you don't get sent to the ref if you get pulled over.
Old Aug 26, 2005 | 09:15 AM
donut.'s Avatar
Default Re: obd0 motor in a ej1? (sicky)
okay?
Old Aug 26, 2005 | 11:07 AM
donut.'s Avatar
bump
Old Aug 26, 2005 | 11:15 AM
Luserkid's Avatar
Default Re: (Hugh G. Rection)
OBD1 injectors, obd1 alt., obd1 dist. and your converted to obd1.
Old Aug 26, 2005 | 11:17 AM
donut.'s Avatar
Default Re: (Luserkid)
thank you
Old Aug 26, 2005 | 12:41 PM
Cvic90's Avatar
You can use OBD0 and OBDI alternators. they have the same plug. OBDII have a different plu and can't be used.
Old Aug 26, 2005 | 12:46 PM
donut.'s Avatar
Default Re: (Cvic90)
wow! is this true? i was about to buy one right now!
Old Aug 26, 2005 | 12:49 PM
JDM-97CX's Avatar
Well if it is anything like my OBD2 to OBD1 swap then you will have to alter more than a few wires like everyone says. Yea, I was told that I would have to lengthen my 02 sensor harness and get an obd2 to obd1 conversion harness and I would be all set.
I had to splice every connector off of the OBD1 harness onto the OBD2 harness. Yea, not fun.
Best of luck.
Old Aug 26, 2005 | 12:52 PM
donut.'s Avatar
Default Re: obd0 motor in a ej1? (JDM-97CX)
actually im not converting my wire harness and ecu to obd0, i want to convert the motor to obd1
Old Aug 26, 2005 | 12:55 PM
JDM-97CX's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hugh G. Rection &raquo;</TD></TR><TR><TD CLASS="quote">actually im not converting my wire harness and ecu to obd0, i want to convert the motor to obd1</TD></TR></TABLE>
Ah, I see, that is a lot easier.
Old Aug 26, 2005 | 01:19 PM
donut.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cvic90 &raquo;</TD></TR><TR><TD CLASS="quote">You can use OBD0 and OBDI alternators. they have the same plug. OBDII have a different plu and can't be used. </TD></TR></TABLE>
true or false?
Old Aug 26, 2005 | 01:45 PM
1truelovedstd's Avatar
Yeah I have pretty much the same swap actually all I did is change the distributer and wired the OBD0 injectors into the OBD1 harness and it runs fine besides the fact that my motor pulses when I try launching but I think that may be caused by the TPS sensor but not sure if anyone can help with that that would be awsome
perseverance
May 4, 2007 06:13 AM
Sleepy_Red_hatch
Mar 4, 2006 08:59 AM
pearl
Jun 28, 2005 10:57 PM
dpw41285
Mar 30, 2004 07:10 AM
VTECyoda
Oct 29, 2003 07:47 AM
